Power Enterprise SP OR Blitz SP
Old Jul 20, 2007 | 06:03 PM
HulksXb's Avatar
Default Power Enterprise SP OR Blitz SP
Hey folks! I am enterested in getting a SP kit for my box. I am leaning more toward the Power Enterprise kit one of the main reason is its proven 40% gain. I am also looking toward the Blitz kit. Which gives the most boost and power to the wheels? If any One has either of these kets I would be glad to here your opinions on them! Thanks guys!
Old Jul 21, 2007 | 04:55 AM
greybox's Avatar
I am in the same boat as you-I am thinking the SC way is easier than turbo and you can still add a header for more gain at the same time.
I would question the GReddy against these as well and then I am also wondering if any of these kits are more or less adaptable to an intercooler than the others?
Old Jul 21, 2007 | 07:53 AM
sizzlinscion's Avatar
Superchargers are no good on a B. Why would your want something that takes power to make power. A supercharger will take about 10% power from the motor just to get boost. You will get alot more power out of a turbo.
Old Jul 22, 2007 | 12:46 AM
jct's Avatar
jct
i vote for power enterprise sp i've seen just one of those and he was from NY and i've seen a hand full of the blitz sp's
Old Jul 24, 2007 | 05:09 AM
DarkBoxJr's Avatar
Old Jul 25, 2007 | 04:57 PM
VIET_BOX's Avatar
Really? I will lose power if I go with a Supercharger?
Old Jul 25, 2007 | 05:10 PM
You wont lose power but you wont gain much. A supercharger takes power to make power, and the 5lbs. of boost that they produce is nothing. You would be alot happier with a turbo and you will see alot more power gains with it.
Old Jul 25, 2007 | 06:16 PM
HulksXb's Avatar
Then why it that susperchargers are the popular choice over turbos? Ive taken a look at the parts section and seems to me that theres more Xb owners buying SP's than Turbos.
Old Jul 25, 2007 | 07:16 PM
VIET_BOX's Avatar
I run the blitz supercharger and i dynoed higher than Blown xA and Tangos xB Greddy turbo untill they upgrade and tune their turbo. so out of the box, blitz dyno's a tad more. Turbo has more potential but theres nothing wrong with putting superchargers on an xB.
Old Jul 25, 2007 | 08:39 PM
DarkBoxJr's Avatar
Pressure is pressure. You're not going to see one benefit over another since these engines aren't even made for forced induction.
Old Jul 25, 2007 | 09:02 PM
pressure is pressure sure....
the engine will benefit from boost either way but why tear your motor up by supercharging it when you can turbo it and get alot better response from boostring your motor...
turbos load the engine evenly, a supercharger loads the end of the crankshaft up. the turbo is taking wasted energy to provide boost where the supercharger is creating resistance in the bottom end of the motor to provide boost.
a turbo loads all of the engines internal bit more evenly then a supercharger, therefor a turbo would be better for a motor period. a supercharger is probably better for tuning simplicity but not necessarily reliability.
Old Jul 25, 2007 | 09:18 PM
DarkBoxJr's Avatar
The only issue as far as reliability would be load on the main bearing from the supercharger pulley, but I haven't heard of any problems with that. The main problem with these engines isn't with the turbocharger or the supercharger, but with the engine itself. No one is going to be running crazy boost on a stock engine, so net output will be pretty much the same. Like I said, the turbocharger isn't going to provide any sort of benefit over the supercharger, and as far as packaging goes, the supercharger is a million times better than any turbo kit I've seen for the 1NZ.
Old Jul 25, 2007 | 11:54 PM
jct's Avatar
jct
Old Jul 26, 2007 | 02:16 AM
HulksXb's Avatar
I heard from power Enterprise that they pulled this off the market due to problem that their SP kit. Has any one else heard about this??
Old Jul 26, 2007 | 02:22 AM
mijos87's Avatar
those set ups are nice! nothing beats that instant gratification like an sc
Old Jul 26, 2007 | 06:24 AM
a turbo will
Old Jul 26, 2007 | 11:13 AM
jct's Avatar
jct
so why is this a turbo vs super charger thread...
btw
in all the drag racing i've seen on tv where a turbo vs s/c...
the s/c wins all the time
and NOS vs s/c or turbo...
the forced air always win
Old Jul 26, 2007 | 03:36 PM
IntenseScion's Avatar
i like both set ups..either way ull still end up hurting ur motor
Old Jul 27, 2007 | 03:30 AM
Old Jul 27, 2007 | 06:26 AM
HulksXb's Avatar
Ummm.......OK!
