Cat back exhaust
Old Oct 5, 2004 | 04:42 PM
xbox83's Avatar
OhioScions
Default Cat back exhaust
I haven't looked under my car yet cause it doesn't have enought miles to change the oil but it kinda looks like the catylitic converter and the center pipe is one piece...now i know i haven't seen a lot of cat back systems for the xB but i was wondering has anybody i guess fabricated a center pipe so that its the same diameter as and axle back cause i was thinking of doing this with the Blitz axle back but was making sure if anybody did this before i go cutting and welding.
Old Oct 5, 2004 | 04:52 PM
Guest
Guest
Posts: n/a
Default Re: Cat back exhaust
I am sorry to say that there are no companies out there making a centr pipe only set-up. There is a cat back you can buy from magna flow, but it replaces your axle back too. To make the center section,you would have to cutt your axle back now to weld onto the new piece to make sure the pipe is the right size all the way through. :D
Old Oct 6, 2004 | 09:38 AM
ScionTCTrav's Avatar
Go MagnaFlow, dude..Its Sweet
Plus Stylis sells it for a awesome price
Old Oct 9, 2004 | 01:30 AM
luvmyxb's Avatar
Try what I did. I went to a custom shop. They cut everything aft of the cat off and on the floor it went. They then ran 2.5 inch pipe back to the new high flow muffler. Everything welded, nmo bolts.Sounds great. Looks great.Costs $175. Might not be stainless, but will last a long time. Makes a big difference along with a CAI.
Old Oct 9, 2004 | 01:35 AM
its_ikon's Avatar
go with magnaflow cat back or if you can't afford it go with the stylis magnaflow axle back
Old Oct 10, 2004 | 02:36 AM
Guest
Guest
Posts: n/a
what kind of high flow muffler? and is it loud? and why the hell would you go 2.5inch on our motor?
Old Oct 10, 2004 | 02:44 AM
JdMBboFSD's Avatar
Default ..
magnaflow cat all the way..........
Old Oct 10, 2004 | 04:14 AM
chucksu's Avatar
Got to be like the B16A Honda guys with monster cams & a fart can. He thinks he needs a 2.5 because they do
Old Oct 10, 2004 | 08:40 PM
squirrel's Avatar
If you want a true cat-back system, Magnaflow produces one. Sure you can go to mufflers shops and have one custom bent for you, but Magnaflow has done all the work already. If you're not running a turbo or s/c you will not need piping any larger than 2.25 inch diameter.
There are many axleback systems on the market also. It just depends on how much you want to spend, and the sound that you are looking for.
Old Oct 11, 2004 | 02:31 AM
Guest
Guest
Posts: n/a
Dude I guess some people want to go back. :D
Old Oct 13, 2004 | 08:17 PM
Technodigifreak's Avatar
chucksu, after I put a 3" catback magnaflow on my civic, My avg gas mileage went from 30mpg to 34mpg, and thats with me running the ____ out of it----altho the moment I added a coldair induction it completely killed that 4mpg gain, so I was back to 29mpg
its all a matter of what your willing to do for a gain in mileage or performance
I highly recommend a highflow cat and/or catback exhaust
and anything from magnaflow is top notch
Old Oct 14, 2004 | 05:45 AM
Guest
Guest
Posts: n/a
Dude once again you cannot compare the honda civic to the Scion at all. The RPMs on a scion run at 3500 RPMs at 65mph. The RPMs on a civic are considerably lower at 65. Now when a motor revs as high as ours does u have to make sure the exhaust is done properly or else say good buy to torque and gas milage.
carid
Feb 9, 2015 01:49 PM
JPuehl
Jan 10, 2015 01:01 AM
TheTripleC
Jan 4, 2015 06:46 PM
PTUNING
Dec 11, 2014 08:09 PM
Besk_one
26
Nov 19, 2003 09:57 PM
