Oil Catch Can for s/c?
Old Jul 26, 2007 | 10:47 PM
jwaggz82's Avatar
Default Oil Catch Can for s/c?
Is there any need for a catch can for use with the s/c?
Old Jul 26, 2007 | 11:06 PM
06SuperWhite_SoCal_tC's Avatar
Yes, very good Idea. I recently got around to installing mine.
Old Jul 26, 2007 | 11:15 PM
The way it's set-up stock I notice that the boosted air goes through the breather on the intake manifold pressurizes the head and blows oil through the other Pre-throttle body side breather.
Old Jul 26, 2007 | 11:18 PM
Rather crude drawing, but I think you can see what Im explaining.
The Charged air that is going through the breather into the head, pressurizing the head, also blows by oil into the other exiting breather tube.
Old Jul 26, 2007 | 11:34 PM
jwaggz82's Avatar
interesting - did you do the homework in which one to get at the best cost?
Old Jul 26, 2007 | 11:41 PM
Garage1217's Avatar
Also on the pressurizing the bottom end, you do loose a small amount of boost when this happens & the pressure in the case is horrible on the seals / bad overall. Was a nasty oversight by TRD. I noted this last year somtime in the sc post I made.
Old Jul 26, 2007 | 11:43 PM
jwaggz82's Avatar
^ please explain a bit more - i missed that post
Old Jul 26, 2007 | 11:49 PM
jetlounge's Avatar
For the S/C, I installed a Dual baffled catch can:
http://blog.scionxtc.com/blogs/archi...catch-can.aspx
For the pressurization issue and reduce blowby I used Krank Vents to increase vacuum:
http://blog.scionxtc.com/blogs/archi...rank-vent.aspx
Old Jul 26, 2007 | 11:59 PM
I just picked up a cheap one for now, from my buddies car shop 222 Motorsports. But later I want to get a better set-up. It works for now though, with the previous stock set-up I was losing oil like crazy due to blow-by... about a quart every couple weeks. Oil level stays constant now with the catch-can, no loss between changes.
Old Jul 27, 2007 | 12:04 AM
This is the set-up I'm interested in. Are there pre-existing holes that you attatch the catch-can to under the battery?
Old Jul 27, 2007 | 12:29 AM
jwaggz82's Avatar
^ read it - it shows you that you use one of the holes from the battery plate
hotwheelsrs1's Avatar
where did u buy those cans and pcv valves, do u have any pn for the pcv's?
Old Jul 27, 2007 | 12:41 AM
jetlounge's Avatar
the can is from Saikou Michi and the krank vents i ordered from Automotive Speed. Links to both of their shops are in the articles.
Old Jul 27, 2007 | 12:48 AM
jwaggz82's Avatar
woo baby - its a few bucks for those few things. I was thinking they were around $80 - good deal though .... I might be down for it .... its too bad there is such a minimal amount of room to work
Old Jul 27, 2007 | 01:12 AM
man, those are pricey, so did u notice a difference on the butt dyno by chance?
Old Jul 27, 2007 | 04:30 AM
Anybody else with a Catch-Can, what did you guys use to plug the Intake Manifold bung?
steeze69
May 24, 2021 02:57 AM
mudguy
Oct 22, 2015 04:31 PM
BlingSlade
Sep 5, 2015 08:52 AM
antayala
Sep 4, 2015 05:12 PM
