White Smoke Question
Old Jul 27, 2007 | 01:42 AM
pollup's Avatar
Default White Smoke Question
At idle recently i noticed im producing a significant amount of white smoke. The smoke smells like normal exhaust, not coolant or anything. I checked the oil, still looks good, no chocolate milk. I checked the radiator, its still topped off. Now i think my spark plugs are overdue to be changed if thats any help. now heres the weird part. if i hold my hand in front of the exhaust and smell my hand it has the smell of burnt electronics. very strange. any ideas? keep in mind i do not drive my car hard and barely, and i mean barely ever hit boost.
Old Jul 27, 2007 | 01:46 AM
Whocares05050's Avatar
Have you recently installed something? maybe along the lines of an oil catch can?
Old Jul 27, 2007 | 01:51 AM
pollup's Avatar
i did install an oil catch can not tooo long ago. but its not where near full. why you ask?
Old Jul 27, 2007 | 01:57 AM
Because I installed one a month ago, a week later the car smoked white, then i took off the catch can, and it stoped. I dont know what happned, but something didnt like it the way i had it hooked up. Everything was right, but i couldnt figure it out. Thought maybe you could be having the same issue.
Old Jul 27, 2007 | 02:02 AM
pollup's Avatar
my catch can is sitting low in the engine bay, it sits below my intake pipe. it is run from the bung where the recirc would go on the factory intake, and it just plugs into the oil catch can. on the other side of the catch can it has a breather filter, thats it. doesnt make sense how that would affect it.
Old Jul 27, 2007 | 02:04 AM
Mine was set up the same way. Just throwing an idea out there to try and help ya'. You could also be burning a little oil on the intake side / exhaust side
Old Jul 27, 2007 | 02:07 AM
pollup's Avatar
would that produce the burnt electronics smell?
Old Jul 27, 2007 | 02:11 AM
Could. Unbolt the downpipe, see if theres any oil. Unbolt a coupler off the intercooler, check for oil.
Old Jul 27, 2007 | 02:14 AM
pollup's Avatar
when i took off my turbo kit originally i did have some oil in the charge piping, but it was at the lowest point near the intercooler. my turbo probably needs to be rebuilt.
Old Jul 27, 2007 | 03:17 AM
Kumitsu's Avatar
Default Re: White Smoke Question
same thing happened to me pollup, the problem with mines was the turbo seals went bad and oil was leaking into my exhaust system. As soon as i installed my new turbo (GT3076R) all the white smoke problem went away after a few minutes of driving it.
my new turbo went bad in just 3 weeks cause the seals went bad again (LOL), talk about luck huh ?
anyways its already been sent out for warranty and ive covered my turbine housing with 3 layers of sheet metal and i plug all the hoses closed , so i can drive my car.
anyways i hope you get your problems fixed.
Old Jul 27, 2007 | 04:10 AM
yamaha16bw's Avatar
You Blew a Garrett GT30 within 3 weeks? Those things should last years and years. You might have more of a problem on your hang then just turbo issues.
Whats you oil PSI at the turbo oil inlet?
Old Jul 27, 2007 | 09:08 AM
pollup's Avatar
not sure on the psi of the oil, thats the only gauge i dont have. should be good though.
Old Jul 28, 2007 | 06:25 PM
Kumitsu's Avatar
i dont have an idea, all i know is that im running a blowby valve, along with the GT3076R stock oil restrictor.
How can i check the PSI at the turbo oil inlet ?
p.s. i dont have oil pressure gauge.
Old Jul 29, 2007 | 05:20 AM
yamaha16bw's Avatar
Get oil gauge. Anytime your working with Ball bearing turbos you need to know the oil PSI.
Check that cause you may need a more restrictive oil inlet fitting.
http://www.atpturbo.com/Merchant2/me...gory_Code=GTBB
Old Jul 29, 2007 | 11:07 PM
Kumitsu's Avatar
thanks alot bud, will defiently look into this.
Old Jul 30, 2007 | 02:16 AM
Syldrin's Avatar
well i know what my third gauge needs to be then!
Old Jul 30, 2007 | 05:17 AM
yamaha16bw's Avatar
No problem man.
I forgot to ask but you do have the water lines hooked up to the turbo correct?
Old Jul 30, 2007 | 02:14 PM
Kumitsu's Avatar
No problem man.
yeah, they are installed by a 1 mechanic shop.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
