amp to stock head unit w/ RCA cables. how?
Old Jul 27, 2007 | 06:04 PM
mrfuzzy4's Avatar
From: 'Burbs Farmington Hills - go to school in Boulder, CO
Default amp to stock head unit w/ RCA cables. how?
how? do i hook it to the front or rear or what.... THANKS!
Old Jul 27, 2007 | 06:09 PM
lil_will's Avatar
ScionERA
You are gonna need a line out converter with the stock deck.
Old Jul 27, 2007 | 06:12 PM
mrfuzzy4's Avatar
i was reading and it said that a RCA cable spliced into the speakers will work.
Old Jul 27, 2007 | 06:50 PM
ajayaitch's Avatar
It won't work well... if at all. Either an LOC from the local stereo shop or a Subplug from Norcalscion.com is the right way to do it.
Old Jul 28, 2007 | 01:14 AM
CanxB's Avatar
The right way to do it is to replace the stock deck with an aftermarket deck with RCA line coming from the deck.
(knowing this, This is my future plan, so the RCA lines from my stock deck are only temporary, This "might" have something to do with this.)
I just set up a Mono amp and sub box in my xb and I purchased the LOC RCA convertor and proceeded with the install with my buddy. After we got it all installed and running he said to me "that in all the years he has help people install amps on to stock stereos, I was the first person he has seen use one of these." I asked him how else would you get the signal to the RCA line and he told me that you just cut of one side of the plugs and splice the wires to the speaker leads from the deck.
One week later I installed new componant speakers in the rear and coaxiles in the dash and doors. I had the rear channels wired to LOC RCA convertor and didn't want to go spend another $30 on a LOC RCA convertor again, so I grabbed one of my old RCA lines and proceeded to cut off the end and wire into the speaker leads and installed a 4 channel amp and plugged both the new and old RCA lines into the amp and patched down to the monoo amp and all is sounding FINE!!!!
Try'd.....Test'd.......Approved!!!
Sorry for the long read.
Old Jul 28, 2007 | 03:13 AM
GROUND_ZERO's Avatar
The install is simple...
Install an SNI-35 (PAC Industries) line out converter. This will convert your speaker (high) level output from your radio speaker wires to a RCA (low) level output for your RCA cables. There is no need to spend money on an aftermarket radio if you don't have it or want it just to add an amplifier to your stock system. To make the SNI-35 "plug-n-play" just pick up a male and female stereo harness (TA02 & TA02R by Scosche) and wire them together matching the colors. Make sure that you wire up the SNI-35 white and wht/blk and grey and grey/blk to the rear speaker wires. The Totota harnesses can be picked up at Wal-mart, along with the line out converter.
I have done literally thousands of these types of installations on various types of vehicles over the last 20 years. It is a no brainer. If you have any questions call me 805-501-3920
-Sean
Old Jul 28, 2007 | 03:19 AM
There's the hacers way to car audio , then theres the professional way to do things. The professional way ALWAYS protects the longevity of product and ensures proper performance.
Old Jul 31, 2007 | 11:39 PM
Olesen_Custom_Automotive's Avatar
Scion Dynasty
he's right
I have a stock h/u with a line converter connected to a 250.2 Rockford amp and a sealed Kicker 12 Comp
sounds fine, works fine, very simple
plus, it helps resell value if you have the original parts in working condition
Old Aug 2, 2007 | 12:07 AM
JDMJim's Avatar
it will work and you'll smoke the amp really fast. don't be cheap.. it will cost you more later. use a line converter or change the radio
Old Aug 2, 2007 | 10:10 PM
JDM speaks the truth!
You asked for advise and you have several people giving you sound advise (and one person giving real $#@^%! advise) listen to what we say.
Do hack your system.. Do it right.
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
prescottn
Oct 8, 2015 05:31 PM
tbone587
39
Feb 16, 2006 07:54 PM
morningman
Apr 29, 2005 12:16 AM
tbone587
20
Dec 12, 2004 01:54 AM
