View Full Version : Where do I hook up a Fuel Sender for a Fuel Pressure gauge
SickleCell
07-29-2007, 03:31 PM
I found a digital pressure gauge and it has a sending unit, but I do not know where I can hook up the sending unit.
Pics would help most!
ippskidder
02-22-2008, 03:03 PM
Someone help us, LMAO.
SickleCell
02-22-2008, 03:08 PM
Tap the fuel rail. I ran a return style line into a wet kit and attached the gauge to a gauge adapter. Problem solved.
ippskidder
02-22-2008, 03:19 PM
Right now I have a stock fuel. Where exactly would I tap it? or would I have to get something welded onto the fuel rail? I'm a little lost =(
and what exactly is a gauge adapter?
SickleCell
02-22-2008, 08:13 PM
Tap the other end of it. Since you aren't on spray or anything, you can have it setup where the fuel sender gauge can screw in where you tapped it.
I recommend having someone that knows what they are doing to do it for you.
ippskidder
02-22-2008, 08:19 PM
Good recommendation, lol.
Hmmm... I wonder how much it would cost to get a return fuel system. So i'm thinking a fuel rail, upgraded lines, walbro fuel pump.
SickleCell
02-23-2008, 12:25 AM
Do you feel that you need it?
Scoobasteve4132
02-24-2008, 05:27 AM
watching for info on return set up!
ippskidder
02-24-2008, 06:08 PM
I'll be sleeving my engine soon. So I know i'll have to upgrade the fuel system. ^^
deathbyc4
02-24-2008, 11:55 PM
if you're upgrading the fuel system, then set it up to return fuel back to the tank so that you can get an aeromotive regulator (which then you will have to block off the regulator in the tank) and screw in the sender into the the new regulator. the expensive way to do it but would be the best if you are getting bigger injectors later. or find a t connector with an 1/8th NPT female to two barb fittings and stick it between the fuel line and the fuel rail where the line is rubber.
SickleCell
02-25-2008, 12:09 AM
If you are doing a fuel system upgrade... tapping the rail and hooking up a fuel pressure sensor is going to be the easy part of that setup lol.
deathbyc4
02-25-2008, 05:49 AM
http://www.jegs.com/p/Mr.+Gasket/746566/10002/-1/10019
just get one of these that will fit the fuel line. snip, clip, screw, done.
SickleCell
02-25-2008, 10:23 AM
you want to be careful with that. Most of the fuel line in our car runs through metal and is covered in hose. By snipping any part of the line, you won't be able to return it back to stock. If you get a bad seal, you may end up losing fuel pressure. Fuel leak would also suck. If none of that bothers you, go for it! lol.
deathbyc4
02-25-2008, 10:49 PM
that's up to the user. i have a return setup :P
xezerax
02-26-2008, 02:17 AM
how long have you been running this setup? no leaks or problems?
soros151
02-27-2008, 02:28 AM
Looks like a good option to me. How about the fuel filter of the tC? Run a line long enough for the gauge to be visible,, but short enough not to drop the pressure.
ippskidder
02-27-2008, 04:58 AM
Without tapping the fuel rail. Is there a place where the fuel line is just rubber, and doesn't have metal piping on the inside? so I can use this barb fitting, and finally using my fuel pressure gauge, lol.
