xA exhaust options...
... are very limited. figured this out after extensive internet research. does anyone know of any manufacturers that make catback exhausts for the xA? and any1 know of any good sites, everywhere i look, its "xB catback xB!!" its frustrating
Try www.optionsauto.com. Search "scion xA"
From my knowledge, most all exhausts out there for our xA is axle back. They may be a few catbacks out now, but i'm not real sure.
Hope this helps.
Hope this helps.
If you don't mind between mendrel or crush bent pipes then custom made at your local exhaust store is not too bad at all. It's certainly cheaper so you can save up for some other mods
Good luck!
Good luck!
custom is cheaper? thats the first time i've ever heard that, i'll guess i'll start searching, thanks!
maybe i'll just buy the magnaflow catback for the xB and tell 'em to fit it on my xA :D
That is true, no one cares. Gabe has a Cat Back. I think most companys, do not take the time to build a cat back. These little cars will not make much more power to off set the cost, compared to a free flow muffler.
My friend's Impreza had a custom 3" pipes made between his HKS downpipe and Borla exhaust, and I think the whole section cost him less than 100 bucks with tax.
I went to a local muffler shop that also does work on a lot of custom cars and race cars. They custom-made a 2.25" catback exhaust for my XA for under $200. I kept the TRD Sport exhaust muffler, and put a new tip on it. It was no biggie for them... they do that kind of thing every day. Was fast, too. They made it while I waited.
Would love to have it dyno-tested to see the difference it has made. I have noticed a big increase in power when it comes to getting on the freeway, when passing, and when going uphill. I would do it all over again in a heartbeat.
Note - Gabe (Stylus) said do not go over 2.25" or you could have a loss of power.
Guest
Posts: n/a
How about a precisionmuffler.com axle back for the xA.
You can also see replies from other happy scionlife customers here:
http://www.precisionmuffler.com/id29.htm
and here:
https://www.scionlife.com/forums/viewtopic.php?t=12451
and here:
Guest
Posts: n/a
nooo... how about a magnaflow catback? thats what i'd really like. why are our xA's so overlooked?
Since our engines are only 1.5 liters, 2 1/4 inch exhaust piping is best unless you plan on some sort of forced induction. You also have to see how the bends are made. If you go to a catback sytem and the shop does crush bending, then you are pretty much defeating the purpose of the system. You want the exhasut to flow just as freely going out, as you want the air going into the intake. That's why you don't see crush bending on most high end intakes. And most sucessful intakes do not have alot of bending.
