I see many people on these forums purchasing springs, but not shocks or struts to go with them.
Isn't that asking to blow shocks in 15k miles or so? Seeing as how the stock shocks are not designed to cope with the new springs?
chris0
10-08-2004, 09:16 AM
I've seen others post saying just the opposite. even though they're shorter, the TRD springs are stiffer than the original springs. shouldn't this prolong the life of the shocks?
10-08-2004, 04:04 PM
Isn't that asking to blow shocks in 15k miles or so? Seeing as how the stock shocks are not designed to cope with the new springs? Actually I am at 25,000 mile and I now need struts. I have been lowered since I got the car. :D
hotbox05
10-08-2004, 06:59 PM
at least they're cheap on this car. just get the lifetime warranty ones from autozone lol cheap but easy . and lifetime can never be bad
ChefRaekwon
10-08-2004, 11:51 PM
Don't be cheap, get the trd shocks with the springs. There designed to match each other in every way. From spring rates to dampnening. You can go without them but I can guarantee down the road they will need to be replaced.
chucksu
10-09-2004, 12:07 AM
:lol: Even if you get the TRD shocks, they to will need to be replaced :roll:. Its a item that will need to be replaced. So would the extra cost of the TRD shocks, out weigh replacing stock like ones 10,000 miles sooner? This is just a guess, the stock could out last the TRD depending on many factores.
TheScionicMan
10-09-2004, 12:16 AM
Damn, Chucksu, you took the words right out of my mouth.
And why replace the brand new stock struts? Replace them after they've worn. 15K - 25K is better than them sitting with my other stock parts forever with no miles on them...
For the cost of the first set of TRDs, I can probably get replacements twice, at least.
Alan
10-09-2004, 12:51 AM
I'm going to give the stock dampers a shot with the Tein s-techs. When they prematurely blow out (which they will), I'll probably go with whichever aftermarket lifetime warranty dampers are out on the market. Hopefully we will see some non-adjustable offerings from Koni, Tokico, Bilstein, H&R, Eibach, etc in the not so distant future.
BeQuietAndDrive
10-11-2004, 02:16 AM
Alan,
I think I'll end up going the same route as you. Hey, I live in Tampa too,I see you post often on TR. I have the same user name on there as here.
chucksu
10-11-2004, 03:03 PM
Also the TRD struts should never need to be replaced
Its a item that is ment to go out. Just like your tires, spark plugs, wipers etc.. How could a company continue to make money off of you if all the parts would never need to be replaced? Also I have read the TRD make the ride much stiffer compared to stock, so if you are just looking for a drop, go with stock shocks. If you want full out performance fork over a little more & get a true coil over system.
doctorcue
10-11-2004, 03:42 PM
Better yet... just save up the cost of the springs & TRD struts & installation... save some more, get some coilovers and install them yourself. I installed my first springs... very easy, just followed the tech section here. The next set of springs and my current coiloveres I paid to have installed. I'm lazy now... 8)
Zombietime
10-11-2004, 04:27 PM
I have a set of hotchkis springs for my XB and they said replacing the stock shocks/struts isn't necessary. The guy I talked with said he has the stock shocks on his car.
kdanie
10-14-2004, 07:36 PM
2 things have advanced the "don't use stock shocks/struts with lowering springs" thought.
1: Installing lowering springs on older stock shocks/sturts. Shocks and struts operate in a limited range on the piston and shaft, over time wear patterns and damage develope and when you install lowering springs you will move the area of operation to a different part of the shaft that may have scratctes from dirt/debris and the seal will now begin to leak. Once some of the oil leaks out it's easy to hit a pot hole or bump and bottom the shock out causing more damage. If the stock struts/shocks have a bunch of miles on them they may just be worn enough to bottom out anyway.
2. Installing lowering springs without a bump stop to prevent metal to metal contact between the strut housing and the strut mount or bottoming out the piston in the strut housing-causing severe damage. Ensuring there is a bump stop installed will prevent this. Driving carefully will also prevent it. If you abuse your car you will damage parts... and it's not the MFGs fault.
Aftermarket shocks/struts with a shorter body are necessary if you go really low to prevent bottoming out in normal driving. If you want to go that low you had better know what you are doing so you don't just screw things up.
I have had Eibachs on my xA for nearly a year and 18,000 mi., it handles as well today as it did when I installed them.
ken
SnyperP
10-14-2004, 07:58 PM
I don't buy the "Save money from double installation" theory. IMO one of great things about modifying your car is doing the work yourself with some friends if possible. I hate it when i ask someone what they're using in the car or what wheels they are and they respond "I don't know, i bought the car like that". Scionlife is a big big place! I'm sure there are many people in everyone's respective area that would be willing to meet a new friend and give them a hand. Spring are easy to install. Springs and struts are even easier to install!
ChefRaekwon
10-14-2004, 11:27 PM
Well if you hate it when people don't know about there cars and know whats on it you should be the first person to know that when replacing springs its best to replace struts/shocks at the same time. People who lower there cars with cheap products or do it halfass to look cool usually have absolutely no clue about cars.
tinybigrig
10-15-2004, 10:11 PM
not like the spring or sock install is difficult on the car, you dont even need a spring compressor...and if your gonna buy shocks why buy trds....theres much better out there, and if your gonna go this far might as well spend a little more and get a full coilover setup
brent
ChefRaekwon
10-16-2004, 01:19 AM
brent
Name 2 companies that produce shocks/struts for the tC? But I agree in time some better companies(Koni, Tokico, KYB) will be produced.
apexjr
10-16-2004, 03:55 AM
Erm... I dunno who makes the TRD shocks, but my guess is Toyota said, 'Hey Tokico (or whom ever), make us a shock for TRD with these specifications.' and that is how the shock was produced.
To say one is better based soley on a name is pure ignorance.
Kong
10-19-2004, 07:56 PM
Guys,
I email Tein to ask on what shocks/struts to be for their spring. Here is the answer....
Kong,
We R&D and develop our lowering springs to be compatible with the OEM shocks.
We perform the R&D testing this way because that is the only constant variable on
all vehicles. There are a lot of other suspension manufactures out there and it would be impossible for us to find out all the different damping force that their shocks provide. If you have anymore questions please feel free to contact us. Thank you for your interest in Tein High Performance Suspension.
Best regards,
Sales
Staff @ TEIN USA INC.
9798 Firestone Blvd.
Downey, CA 90241
Phone: (562)861-9161
Fax: (562)861-9171
I guess springs work on OEM stock shocks/struts afterall .. :)
TheScionicMan
10-19-2004, 10:27 PM
I was inspired by Kong's idea to ask someone who knows instead of us all debating it. Here's the response I got from Jeff at GoldLine:
Gold Line (along with most other spring companies) design their product to
work with factory shocks/struts. Not to say that overall ride/handling
quality cant be improved by going to an aftermarket shock/strut.
Sounds like we were on the right track from the beginning...
dante
10-21-2004, 03:18 PM
question from a total n00b here, but doesn't this also depend on the AMOUNT of the drop? 1" drop from TRD springs that are stiffer than stock would probably work fine with the stock equipment, where a 2"+ progressively wound spring would not, correct? thanks!
TheScionicMan
10-22-2004, 08:15 AM
TEIN and GoldLine both have a 2 inch drop and they both said they were designed to work with the OEM equipment.
If TRD's 1 inch drop was designed to work WITH the OEM stuff, why do they sell the struts and shocks, and scare you into thinking you need them?
EVILDAVE
10-22-2004, 02:19 PM
If TRD's 1 inch drop was designed to work WITH the OEM stuff, why do they sell the struts and shocks, and scare you into thinking you need them?And the answer is $$$$$$$$$$$ they want it all.
therotman
10-22-2004, 02:37 PM
Factory vehicle suspensions are designed for everyday street use, but do not meet the needs of more advanced drivers. TRD's shock absorbers and struts, however, are specifically designed to accommodate the aggressive driving style of today's performance enthusiast. TRD has analyzed the data derived from extensive testing conducted on each model vehicle, under a variety of driving and road conditions. The result: shock absorbers which have been perfectly tuned to provide enhanced road feel, better cornering and roll resistance and consistent damping performance under heavy-duty use. TRD's line of shock absorbers provide the perfect blend of performance, durability and safety under even the most demanding use.
http://toyota-trd.jp/en/strt/s_shckab.html
They are a more agressive shock. You can use the OEM ones to save money, but a month later you will wish you just did it right the first time. I just ordered them both and they should be arriving this Monday. I will pay a local shop $50 to install, and it will save me an entire Saturday. I have the know-how and tools to do it myself. I give some dap to anyone who does it themselves, but being able to relax on a Saturday is worth more than $50 to me- 8)
