Need help with 8 wire ground kit
Old Oct 8, 2004 | 02:37 PM
axiom's Avatar
Default Need help with 8 wire ground kit
I recieved my ground kit with no instructions, does anyone have a diagram or anything to show the eight ground points?
Old Oct 8, 2004 | 02:48 PM
BrockAbabba's Avatar
I was worried when I got mine too. Then I just stared under the hood and it all became very apparent. Look above you drives headlight, see that crappy pile if white wires screwed the radiator support, replace that. See the one that runs down from the negative terminal to the tranny. Replace that. See the one on the strut tower behind the batttery, the one on the passanger side strut tower.....you get the idea. You can't screw it up, just improve every ground the vehicle already has. The only tricky part may be the alternator.
YOU CAN DO IT!!!
-the Waterboy
Old Oct 8, 2004 | 02:55 PM
axiom's Avatar
Now I did see a picture of a four wire setup that had one wire going to one of the sparkplugs, Is that a good or bad thing?
Old Oct 8, 2004 | 03:23 PM
ikhonlord's Avatar
Here is the FAQ for the 4 wire kit. I am not sure about the 8 Wire...
https://www.scionlife.com/forums/vie...d+wires#312514
:D :D
Old Oct 8, 2004 | 03:40 PM
DJ_X_Trodinaire's Avatar
what company did you buy it from?
Old Oct 8, 2004 | 04:27 PM
mikochu's Avatar
It is not directly on the spark plug, but the bolt that holds the coil cover on the sparkplug... It's 100% safe.
Old Oct 8, 2004 | 05:23 PM
axiom's Avatar
Good, that's where I put it, I bought the kit on ebay ($7.99) from M1performance but when you try to go to their website, it does not exist.
Old Oct 8, 2004 | 05:33 PM
manejounxa's Avatar
Mine is coming in from groundfusion.com (sponsored seller here)
paid $73.00 but if I have question im sure I could reach someone there via e-mail as I had some question prior to ordering and they where very helpfull....juan
Scion0814
Scion tC 1G Aero & Exterior
Feb 15, 2015 10:02 PM
NewBox06
Feb 3, 2015 12:36 PM
kagero79
57
Nov 14, 2008 01:25 AM
Scionic
199
Jan 8, 2006 11:09 AM
arinvolvo
Jan 21, 2004 11:40 PM
