So I hit the dyno today
So I got my car dyno'd today. Its stock with the exception of a 9.5psi pulley and a Greddy Sp2 cat back. I think there is something wrong with it though because Im not able to get to 9.5 ish psi of boost, im sitting rite at about 7 under WOT. Any way the numbers are
195 HP
172 Ft LBS
185 HP (with ac)
160 Ft Lbs (with ac)
Ill have the graph up monday.
195 HP
172 Ft LBS
185 HP (with ac)
Those numbers seem really low, 195 hp is what a stock supercharger runs, which makes sense since you're only hitting 7psi. Change your bpv to a forge 007 and see if it makes a differance in your boost threshhold.
yeah, we recently had ours done; and with stock sc, 110, and trd exhaust ( i know it's nothing, but it's on the car ) we were just under 192 hp/168 tq... and that's with us being told the plugs needed to be replaced. So i'd say from my limited experience that you are still running the stock bpv which must be leaking like a sieve, or perhaps the belt is slipping?
Originally Posted by krdshrk
The problem is your BPV - the stock BPV can't take past 7PSI and that's why you're not getting up to 9 pounds.
Change that BPV ASAP to see your extra PSI's.
Well I just put a turboxs type 25 in it, shimmed it with 2 washers and now Im getting ~9.5 on my boost gauge. I just need to fix my oil leak where my oil pan was tapped at. And yeah I meant Axel back.
Originally Posted by 06SuperWhite_SoCal_tC
Originally Posted by olaHalo
its your fuel map. its got a nasty hole. thats why your unloading in third
jokes are getting kinda lame as of late...
Ferretgrrl
Oct 15, 2018 02:50 AM
dchan8
34
Mar 26, 2004 04:37 AM
Wide_tC
Jan 15, 2004 01:00 PM
