Engine maintenance Light...
Old Oct 9, 2004 | 07:03 AM
xdorkx's Avatar
Default Engine maintenance Light...
Hi, i did a search (too many &*(^&*^ results). for this, tonight i noticed that my "eng maint" light (i think thats what it's called) was on...i had the trd muffler, and the aem intake installed about a month ago, but never had this light come on until tonight. I DID try unplugging the neg battery connector for about 2 minutes, and starting it back up...but nothing happened except my muffler sounding louder (heh)....so, after doing a search, and finding nothing...anybody have any advice, or a link to a prior thread?
thanks for your help in advance
Jeff
Old Oct 9, 2004 | 07:07 AM
JdMBboFSD's Avatar
turn car on then, then turn offf, the turn the key so that just the radio comes on......while doing that press the trip meter thingy for a few seconds, then let go........then walla.....try that........i think.........go try it now....... :D
Old Oct 9, 2004 | 07:08 AM
xdorkx's Avatar
You're kidding....right? :?
Old Oct 9, 2004 | 07:09 AM
JdMBboFSD's Avatar
no .....i am not kidding.......try it.......
Old Oct 9, 2004 | 07:10 AM
xdorkx's Avatar
ok i'll go try that now, heh, (the trip meter thing threw me off)...back in a few (i'm not unplugging the battery again, hopefully i dont need to)...if i should though, let me know...
Old Oct 9, 2004 | 07:16 AM
xdorkx's Avatar
well, i tried that twice....nade ,, but thanks anyways
any other advice?
jeff
Old Oct 9, 2004 | 07:19 AM
JdMBboFSD's Avatar
any other advice?
jeff
found it .........
1. Turn on the ignition and make sure it is on your odometer display, not the trip display.
2. Turn off your ignition. Hold down the trip meter reset button and turn the ignition on. Keep the button pushed in.
3. The maintenance required light will flash for a few seconds. when it turns off, let go of the reset button.
i was way off......
Old Oct 9, 2004 | 07:25 AM
xdorkx's Avatar
dude, you're the man, worked like a charm, thank you so much, i was stressin over that...............
it's appriciated
jeff
btw, how'd that work, that the engine reset code or somtin?
Old Oct 9, 2004 | 07:29 AM
JdMBboFSD's Avatar
it's appriciated
jeff
no prob bob .......i dont know how that worked......to tell ya the truth......let someone else answer.......it happened to me too........so i went through what u went to ........... :D
Old Oct 9, 2004 | 07:30 AM
xdorkx's Avatar
works for me, well thanks again, anyways, mufflers louder now too, hehe
Old Oct 9, 2004 | 08:21 AM
chris0's Avatar
Default Re: Engine maintenance Light...
disconnecting and then reconnecting the battery made the muffler louder? wtf?
Old Oct 9, 2004 | 08:29 AM
mikochu's Avatar
yeah, it resets the ECU...meaning it'll redo the fuel maps...so the muffler sounding loud would occur because it doesn't know how to manage the fuel...
xdorkx, I think the maintenance light comes on when you need to change your oil. The Check Engine light come on when your maf throws fits...
Old Oct 9, 2004 | 09:14 AM
xdorkx's Avatar
cool thanks again, and yeah concerning the muffler, resetting the ecu DOES do that, as the engines cpu doesnt' yet know how to "respond" to the muffler, and intake (being non stock)...
thanks again for the help
night
-jeff
Old Oct 9, 2004 | 02:45 PM
Theglen10's Avatar
As far as I know the "eng maint" light is just a change your oil light, based loosely on temp, rpm, & miles. Is it time to change your oil? Turning it off does not change the reason that it was on. Check this out. Also, the proceedure to turn it off is in the manual, oh yea I forgot, we men don't read stinking manuals. LOL!
Old Oct 9, 2004 | 05:15 PM
UnFocused's Avatar
when in dought: READ YOUR OWNER'S MANUAL!!!
Old Oct 9, 2004 | 07:18 PM
xdorkx's Avatar
and when in DOUBT, learn how to spell
Old Oct 9, 2004 | 07:50 PM
FeeLTHeBuRN's Avatar
Scion Dynasty
if you get your oil changed before you hit the mileage before the light goes on it will still go on at the 5000 mark right becasue i got mine changed at 4000 and at 5000 that maint. req. light came on and I don't know if the mechanic can reset it if it isn't on. does anyone know? because I don't want to reset it if it isn't for my oil getting changed.
Old Oct 9, 2004 | 08:12 PM
xdorkx's Avatar
well mines just at 7500 mark right now and i got my oil changed at 4000, so it's not that, i'm assuming it's just the intake, or the muffler (or both combined)..but regardless, the cars running great, and the light hasn't come back on for me..
Old Oct 9, 2004 | 09:18 PM
wgeee7478's Avatar
Usually the maint. req. light comes on every 5000 miles from the last time it was reset. My wife just went through her first oil change and they forgot to reset the maint. req. light too. And as for the exhaust, my personal belief is that if you do any kind of performance mod, you should disconnect the battery so the ECU can reset itself. Then after re-attaching the battery, start the motor and let it idle for about 10-15 minutes so the ECU can do it's little boot up procedure and re-map the fuel curves and etc. This may not be everyones recommended procedure but it has worked for me on my Integra, my wife's old Civic, and now her new Scion.
Old Oct 9, 2004 | 09:28 PM
TheDanger's Avatar
Just wondering why we have owner manuals anymore...it cleary shows all the lights and tell you what they are "change oil" ugh...
