Removed Balance Shafts. w/dyno
Old Aug 5, 2007 | 10:07 PM
KCTTC's Avatar
Default Removed Balance Shafts. w/dyno
Before and after removing balance shafts.
Differences from above dyno.
Stock vs current dyno
Differences from stock to current.
-Jeremy
Old Aug 5, 2007 | 10:23 PM
Tcguy85's Avatar
what do the balance shafts do? they must be there for a reason.
Old Aug 5, 2007 | 10:31 PM
xIxAMxHOLLYWOODx's Avatar
you're completely stock? Just removed the shafts?
Old Aug 6, 2007 | 12:05 AM
satoman44's Avatar
wow, didn't know they were going to make THAT big of a difference. wonder how it will affect long term engine reliability/life.
Old Aug 6, 2007 | 12:18 AM
SoccerBoy_AP's Avatar
Balance Shafts = ???
Old Aug 6, 2007 | 12:34 AM
3min3m2's Avatar
wow....30 hp???
what are the balance shafts, and how do i get rid of them!!!
but honestly, can you get/give some pics of removal and more info??
Old Aug 6, 2007 | 01:01 AM
Crayola_G's Avatar
yea seroiusly, how did you go about removing them. what the balance shaft does is prevent engine vibrations correct? I mean if we dont need them inthe tC get them the he11 out is what i say, 30 hp is famazing, and asked eralier wat do u see in the longrun?
Old Aug 6, 2007 | 04:57 AM
Whocares05050's Avatar
Interesting...
Old Aug 6, 2007 | 05:40 AM
adg016's Avatar
NO NO NO. Removing balance shafts does not produce 30 whp. Perhaps the OP will clarify for you guys.
Old Aug 6, 2007 | 05:41 AM
tC9o9's Avatar
He has I/H/E and a camcon unit
Old Aug 6, 2007 | 05:43 AM
soros151's Avatar
nice... and it's not 30hp, its actually from 166 to 172. Thats 6whp more. NICE!
Old Aug 6, 2007 | 06:10 AM
KCTTC's Avatar
I give thanks to the people that actually read the whole post before replying.
Balance Shaft Removal = 6 hp and 3.4 ft/lbs.
Thanks,
Jeremy
Old Aug 6, 2007 | 06:48 AM
Ty_Max's Avatar
Now the verdict...safE?
Old Aug 6, 2007 | 07:00 AM
bluaeon's Avatar
finally... someone brave enough to remove the bs on a tc... but question for you though... ive owned a spec v before and i know that car had a single bs, and there was a kit for it to minimize the slush of the oil... its like a baffle plate... well... my question is... what did you use to do this? did you just remove it without any kind of baffle? also, did you add 1 qt of oil instead of the usual 5 qts?
Old Aug 6, 2007 | 01:31 PM
SeanstC's Avatar
i imagine it would be about a quart of oil, the whole unit is about that size anyways
Old Aug 6, 2007 | 02:37 PM
adg016's Avatar
With our shafts removed and our oil cooler setup, our capacity is now 6 qts.
Old Aug 6, 2007 | 03:12 PM
soros151's Avatar
Care to make a video of how the revs move now?
Old Aug 6, 2007 | 07:53 PM
bluaeon's Avatar
i would imagine that this would happen... specv guys had to add 1 qt of oil as well... but what did you replace it with in its place? did you just cut the bolt and left the balancer intact?
Old Aug 6, 2007 | 11:03 PM
3min3m2's Avatar
Thanks,
Jeremy
the labelling of the dynos is a little misleading
it just says stock vs now w/obs
but anyways, does anyone care to elaborate on the removal, etc.
Old Aug 6, 2007 | 11:22 PM
InfideL's Avatar
congrats on the hp gain thats awesome for a free mod
plus the added throttle response and minor weight loss
i've been following this for a while
is there a DIY out there yet?
