Injector Issues on new Greddy kit
Old Aug 7, 2007 | 04:34 AM
TCinSC's Avatar
Default Injector Issues on new Greddy kit
I have an 05 tc with the standard greddy kit (18g turbo, 440cc injectors, emanage blue). I've checked the wiring several times, and have the fuel settings on the emanage down to the lowest level, yet my injectors are still spewing fuel.
I've hit a brick wall with what else I might even check, and I'm just looking for some input as to what else could be going on. The car will crank flawlessly, then as soon as it settles from the cranking rev, it chugs, spits fuel, and stalls due to flood.
Any input would be greatly appreciated.
Old Aug 7, 2007 | 05:50 AM
Angry_Celi_Guy's Avatar
i think i read somewhere its the dipswitch settings, i dont know them personally but maybe some one can explain some more.
Old Aug 7, 2007 | 06:37 AM
BuddhasTC's Avatar
check the O-rings...i had the same problem and it was the O-rings
Old Aug 7, 2007 | 08:52 AM
greddy05tc's Avatar
the jumper issue i think was only in the emanage ultimate. not sure about the blue.
Old Aug 7, 2007 | 02:05 PM
TCinSC's Avatar
I checked the jumpers, and the jumper settings are correct. With the o-rings, am I just looking to make sure they're seated properly on the injector?
Old Aug 7, 2007 | 03:42 PM
ucyib2papi's Avatar
and/or actually there
Old Aug 7, 2007 | 08:44 PM
BuddhasTC's Avatar
and that there's no play in them...squeeze the sides of the o-rings...if there's play, then they're bad
Old Aug 7, 2007 | 08:59 PM
ucyib2papi's Avatar
oh and while ur at it, get rid of the wastegate and get an external one :D
Old Aug 9, 2007 | 07:44 PM
TCinSC's Avatar
well, i pulled out my injectors. needless to say, my o-rings were fried. thanks for the input
Old Aug 10, 2007 | 07:27 AM
BuddhasTC's Avatar
glad to help...same problem with mine when we put on my s/c setup...good thing is they're cheap and u can get them at autozone
Old Aug 11, 2007 | 03:19 PM
TCinSC's Avatar
Ok. the final resolution looked more like this:
the rubber grommets from the injector to the head were bad, and I had a pinched wire on one of my injectors, so it was running wide open. Everything is running solid now, except the extreme need for a tune
cessblood
Sep 15, 2015 06:50 AM
darkshadowofxdeath
Feb 11, 2015 05:38 PM
jdstC1
Jan 13, 2015 04:45 AM
TheTripleC
Jan 4, 2015 06:46 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
