View Full Version : I NEED TO KNOW IF THIS WILL RUB
ksl_redsoxfan
10-10-2004, 06:26 AM
i have 18x7.5 wheels with tires that are 215/40/18 and i need to know if thats gonna rub if i drop it 2", and if so will it if i remove the plastic pieces in the wheelwell? 8)
DenZinz
10-10-2004, 06:29 AM
it shouldnt, what offset?
ksl_redsoxfan
10-10-2004, 06:37 AM
i'm not sure what the off set is
DenZinz
10-10-2004, 06:53 AM
thats going to be the decidng factor....
do you have a pic of the wheel?
MyBoX
10-10-2004, 07:26 AM
Kevin, You should get the goldlines for your silver box and then put these on and test drive the car, that way you know exactly what you should get for your lava !!! Sean
MattyRattyPoo
10-10-2004, 07:42 AM
Dude go with a 215/35/18. That's what igot. 40's will rub. Add a 2 inch drop and you'll be stylen!
BLeeK
10-10-2004, 05:43 PM
with a 40/18 you may get a bit of rubbing, if you go with a 35/18 then Im confident if you have a goldline esque drop you will not rub...
ksl_redsoxfan
10-10-2004, 07:37 PM
i want to keep the 40's because it will look sick if i can get it not to rub because it will fill the whole wheelwell and it would look awsome. i think i will have to gut the wheelwell's and i think i should be o.k., if not i can always put the springs on my other xb. 8)
quadoptix
10-11-2004, 07:47 PM
just depends on the offset.
BoomBox757
10-13-2004, 09:06 PM
I have 215/35/18 and mine rub on a full locked turn, its all about the offset, mine is 44(?) so thats why
BoomBox757
10-13-2004, 09:13 PM
ohh and I have a 2" drop (spy springs)
