stock sub options
Old Aug 8, 2007 | 03:52 AM
jrmurillo's Avatar
Default stock sub options
what do u think of the stock sub and what other options do i have of subs that fit into that same contraption
Old Aug 8, 2007 | 01:16 PM
Amoxaphobic's Avatar
Your list of subs is a pretty large one. I do believe that the stock sub is 10", and there are a lot of 10's out there on the market. Your only real problem will be the height of the sub... also, I am not sure if the stock sub box has an amp in it, but if you get an after market sub then you will prolly have to get a new amp.
The stock sub is ok, but it's def not show sound quality. I guess it really depends on what you are looking for. If you just want a little thump at a low cost, go with the stock box. If you want more, save up and get your money's worth.
Old Aug 8, 2007 | 01:19 PM
blazeplacid's Avatar
i dont even think the stock sub is worth it.
Its pretty pricy from the dealer.
you can get one off line for about 200ish.
Really up to you.
I had the Bazooka sub and it wasnt enough for me. I liked the idea of having a sub that would fit and look factory,but It wasnt enough.I even swaped out subs and used a seperate amp.
I belive the factory amp is about 50rms.
Id go to the dealer and take a listin
Old Aug 8, 2007 | 01:31 PM
nebster's Avatar
bazooka sub = sucksors.
buy a real sub and enclosure. you'll be much happier
Old Aug 8, 2007 | 05:21 PM
XtCScIoN's Avatar
can you buy just the box from the dealer?
Old Aug 8, 2007 | 05:44 PM
nebster's Avatar
no its sold as a set. and that box is really a POS. requires way to much work. flimsy and wouldn't hold any aftermarket sub properly
Old Aug 8, 2007 | 08:42 PM
robtheqb2003's Avatar
Are you looking to rattle windows as you drive by or just looking to add some nice bottom end bass? If you are looking to set off alarms as you drive by, don't even think about the stock sub. Get some 10" or 12" subs in a nicer enclosure. If you are just looking to round out your sound system, I highly recommend the infinity basslink II. I have that one and it sounds nice. Its not going to wake up the neighbors, but it will nicely accentuate your sound system...
rocefresh
Scion tC 2G Wheel & Tire
14
May 20, 2015 03:23 AM
SloTC1
Apr 2, 2015 07:11 PM
PTUNING
Dec 6, 2014 03:58 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
umnitza
Dec 1, 2014 06:26 PM
