not building boost
Old Aug 8, 2007 | 05:36 AM
Enrique9876's Avatar
Default not building boost
ok people so heres the problem... i have a zpi set up (16g) with 550cc inj. and the emanage ultimate... ive checked all my intercooler piping, vacuum lines, blow off valve, and boost controller and everything seems perfect....BUT im not building ANY boost... i dont know what the issue could be ... all i can think of is a bad turbo... has anyone else had a problem like this with the 16g OR does anyone know what the issue could be? any help would be appreciated.
Old Aug 8, 2007 | 05:44 AM
ignitionr34's Avatar
any smoke coming out of the exhaust? Blue smoke usually means blown turbo. Other wise it could be a leak somewhere?? thats what it sounds like
Old Aug 8, 2007 | 05:51 AM
i think there is only smoke when i first start the car up... but my tune is REAL rich down low ... so i think its due to that... ill check that though... thanks
Old Aug 8, 2007 | 05:55 AM
as an after thought... what could cause a turbo to blow?
Old Aug 8, 2007 | 07:26 AM
Whocares05050's Avatar
ur seals could have gone bad. take all your pipes off, and reinstall them to make sure there isnt a possibility of a leak. Check for oil on the intake side, and unbolt the downpipe and check for oil. make sure emanage is solid green. report back.
Old Aug 8, 2007 | 08:12 AM
malibuboy54's Avatar
how and where are you routing your vacuum line to/from?
Old Aug 8, 2007 | 10:48 AM
RSracer's Avatar
do you even hear your turbo spinning? Do you have water cool lines to it or a turbo timer?
Old Aug 8, 2007 | 12:37 PM
318_tC's Avatar
bad turbo or cracked manifold
Old Aug 8, 2007 | 03:03 PM
brett561tc's Avatar
take off your air filter
eujin
Feb 23, 2016 01:18 AM
crimson_sinn
Sep 25, 2015 09:41 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
EVILDAVE
Sep 15, 2015 06:54 AM
