View Full Version : xD on Yaris coilovers
FLINT
08-09-2007, 07:00 AM
Is there 1 on SL yet? I heard it had been done.
jspectoaster
08-18-2007, 03:42 AM
can anyone verify if Yaris springs will fit on an xD.cause the yaris sedan df210's drop a lil over 2" and that would be sweet :pray:
toyoda
08-18-2007, 03:56 PM
If not the yaris, maybe the Matrix ones would? Just an idea
L4rry_B1rd
08-18-2007, 06:56 PM
Are the weigts similar between xD and Yaris?
toyoda
08-19-2007, 08:42 PM
Approx curb weight of the Yaris is 2,321 and the xD is approx 3,086. Way too different. The Yaris springs would sit too low, have too much pre-load tension on up-travel, and would wear out and sag prematurley(sp). I would not do this. Maybe invest in a coil-over kit designed specificly for the xD. A much more sound idea IMO.
Boxer_Rebellion
08-20-2007, 04:22 AM
Nope, the xD weighs just over 2600 lbs. You're thinking of the xB2.
MattyRattyPoo
08-20-2007, 04:27 AM
Regardless you will have improper spring rates with using springs made for another car. I say wait for companies like Tanabe to come out with springs for the car.
CASTREX
06-09-2008, 06:09 AM
Part numbers for the Tein Basic Coilovers, are the same for the xD and for the Yaris. Tanabe springs are also the same part number, both DF's & NF's
That means that the xD currently has a LOT of suspension/coilovers/springs options available.
Yang
06-09-2008, 07:05 AM
+1 on same springs from tanabe
http://img150.imageshack.us/img150/9806/dscf0315fi5.th.jpg (http://img150.imageshack.us/my.php?image=dscf0315fi5.jpg)
or you have go to tanabe's site here and look at yaris and xd same model http://www.tanabe-usa.com/springs/spring_applications.asp?id=2
pickledchang
06-09-2008, 11:20 AM
+2 here... when my NF210s came in, it said "Yaris" right on the box.
SHIFT_xA
06-09-2008, 11:51 AM
maybe the 4 door yaris?!?!?
tmrepp
06-09-2008, 04:57 PM
Get a set of coilovers with a spring upgrade (heavier)...ksport will do it, and I bet progress, tein, etc. all would too if they have a kit for the Yaris.
JDMJim
06-09-2008, 08:40 PM
whatever we say, people will use them anyway even if they are wrong... I mean, look how many peeps don't upgrade their shocks and should...
pickledchang
06-09-2008, 10:58 PM
please justify that.
the part number for the NF210s is the same for the yaris sedan and hatch, as well as the xD, TNF121. ride height is different for each because of weight, naturally.
same thing with the tein basic dampers, part number for the yaris is the same for the xD, DSC10-LUAS2. even the part number for the springs that come with the kit are the same, front and rear, S8L70-11040 and S6L71-01031, respectively.
so am gonna go out on a limb here and say that xD springs ARE yaris springs...
see for yourself:
http://www.tein.com/products/basic_price_list.html
Garage1217
06-09-2008, 11:01 PM
whoa were in the world did you get those numbers..?
ChelsDS
06-10-2008, 06:10 AM
Hrm the chassis of the Yaris and xD are the same, so theoretically parts should work on either vehcile. The rear sway for the xD said Yaris on the box when I got mine. The Tanabe springs are the same for the Yaris as well. Though I could be careful getting other parts and swaping them on the xD.
JDMJim
06-10-2008, 04:07 PM
[quote=JDMJim]whatever we say, people will use them anyway even if they are wrong... I mean, look how many peeps don't upgrade their shocks and should...
I mean that stock shocks are not valved for a higher spring rate that would of course ruin the shock prematurely. replacing shocks when upgrading springs SHOULD be a no brainer. My wifes tC is still on stock shocks with white TRD springs. I can tell the shocks can't keep up with the springs. the car understeers horribly when pushed. The xD needs a rear sway bar badly. It doesn;t know if it should turn or not when pushed. But I guess only people that have done this correctly in the past would know. last car was all suspension and little engine work. Still made for a quick car in the twisties which was fun messin with more powerful cars.
pickledchang
06-10-2008, 10:14 PM
phew, we should all be thankful then that someone has done it absolutely right and saved us all from a life full of premature shock failure.
anyone know if the TRD shocks are gas-charged?
tmrepp
06-10-2008, 10:33 PM
I hear they're Toyota-charged$$$
pickledchang
06-10-2008, 11:04 PM
lol, don't doubt that.
JDMJim
06-10-2008, 11:32 PM
no need to be a smartass. :loser: just tired of peeps complaining bout blown shocks and shoulda coulda woulda...
ChelsDS
06-11-2008, 01:04 AM
The only shocks out there at the moment are TRD so if you get Tanabe then.. aren't you s.o.l. already? I haven't even heard anything about Tanabe coming out with shocks for us. :?
pickledchang
06-11-2008, 04:17 AM
you should be able to use the TRD shocks with the NF210s... any suspension gurus already here want to enlighten on this?
SeattleGuy
06-20-2008, 05:40 AM
Don't know bout the guru bit but I felt my NF210's needed more rebound dampening. TRD struts/shocks eliminated a "pogo-stick" suspension reactivity that bugged me from time to time. Everyday ride doesn't seem any harsher. Install was easy - like springs - with no unexpected issues.
pickledchang
06-20-2008, 04:48 PM
did the TRD shocks help with cornering and handling, or just improve the ride? did they help remove body roll at all? and i guess this means the TRD shocks/struts work just fine with the NF210s...
SeattleGuy
06-20-2008, 05:17 PM
Yeah they work fine with NF210's. On smooth surfaces the handling and body roll isn't too different than with stock... Better but subtly so. Think most of the body roll issues were addressed by simply lowering the centers of gravity and rotation with the spring swap. The problems I experienced were mostly on choppy roads - which abound in Seattle - especially when the suspension unloaded rapidly. It wouldn't bounce exactly cause the stock dampening rate is pretty good but sudden unloads affected both ride and suspension stability. A handling example: Hit a sharp bump in the middle of a turn and it felt a bit like the steering angle was affected a la bump steer. Probably mostly subjective but unpleasant. Doesn't do that now. Ride is better IMO simply cause you don't get thrown around as much on a really bad road. The car certainly isn't as cushy as pure stock, perhaps even a little less so than with NF's alone, and communicates more noise but I like it better. It is a pretty expensive subtle improvement though, even as a diy.
