View Full Version : one ton garage hub spacers
u83rp5ych0
10-10-2004, 09:44 PM
Ok ive got a question for those of you that have had the rear hub spacers from one ton for a while. Have you expirenced any problems with them. What grade are the bolts, are they grade 8? The longer you have had the spacers the better, I just want to make sure that they are not going to cause any long term damage to my box.
quadoptix
10-11-2004, 07:47 PM
vans shim spacers r fine.. i have them on my box, never had any problems w/ them.
TheScionicMan
10-11-2004, 07:54 PM
I just got mine recently but haven't put them on yet. They are SOOO gorgeous, I feel bad hiding them behind the wheels where nobody will ever see them.
As for the bolts, they say JH 8.8 on the tops...
Itchy
10-11-2004, 11:35 PM
I have them on my XB and they work great...no problems.
projxB
10-11-2004, 11:51 PM
i have a set also, their not installed, but i have a set. If only van would produce the spacer shims with the camber plates integrated, i need some camber before i go pushing my wheels out any further. :wink:
10-12-2004, 12:04 AM
I have had my spacers since he started sellin them and I have had no problems what so ever. I have been to LA, Las vegas, San Luis obispo, and sacramento so many times. And not one spot of vibrating loosening or anything else. Go for it man, buy them and get your box upgraded already. :D
mru2
10-12-2004, 01:15 AM
Absolutly no problems. Cool mod and easy to install. Read the how to guide in the tech section (i think). Only trick to it was the removal of the ABS sensor jack. Pay close attention to where you stick the screwdriver in the instructions that come with the spacers, ( closer than i did at least....) 8)
Black_Kilinky
10-12-2004, 03:00 AM
I just got mine and I'm installing them tomorrow I hope, for anyone that has done them....do you really have to go to the 46lbs or did you just skip that step? does it matter?
squirrel
10-12-2004, 05:39 PM
I asked Van to produce a set for me a looooooong time ago, and I still haven't gotten them yet. But now I'm changing things up, so I have no need for them. Alot of peeps are running the spacers, and haven't had any problems.
