warranty after turbo lol
For those of you who just read the short blurb at the top, a turbo puts undo stress on the motor, so if anything happens to your motor or to yoru transmision, it will be very easy to prove that the turbo was the cause of it.
So, yes, turbo = no more warantee for engine and transmition.
Originally Posted by toolz
unless you just installed everything to stock again. could they really prove you had a turbo on it?
But if they really tried hard enough, the probably could.
They could just look into the black box and check how many times you hit the rev limiter or how hard the car was run and then not warantee it because the car was abused.
They cann't void your warranty because the car was redlined. The redline is there to be hit, trust me the red line is way before the car can be damaged. And all new cars anyways stop the engine from over revving to prevent damage. Go outside and red line it, all it will do is sound like it's running out of gas like a on and off on and off, type of running. Those boxes are really used for traffic accidents so you can tell if somebody was speeding and out of control and that's the only way they can be used. And even using the box for that purpose is a problem when lawyers get involved.
Originally Posted by Mr_Meaty
Aw, c'mon, I was just trying to scare the kit out of installing a turbo, breakign something, taking it off and expecting warantee to cover it!
Now I agree that lying and dishonesty is bad, but you have already lied, the OP is just considering it.
um.....OH, I KNOW! I didn't lie. I was just misinformed!
OH, how about, "I was only lying to him to protect him!"
"it was for his own good!"
Yes JoMac is right, they will be able to tell a turbo has been there even though you have removed it. Do what i'm going to do wait until the warranty is up and the car is payed for, then buy the xb3 and install turbo that has been fine tuned for 4 years, meaning 4 years later from now. And enjoy your fast xb2 while you modify your xb3. That's what i'm going to do at least that's what i hope on doing.
Originally Posted by L4rry_B1rd
They can check the ECU and see the huge increase in air-flow and fuel... so yes they will be able to tell a turbo was installed even if you remove it.
OR, you could just do it, stick it to every nay-sayer here
and then bend over when you have to get your car worked on.
Just know that technology will keep you in line, ie, you won't be able to lie about turboing your xb. a lot of people have done it... consult them first. weigh the pros and cons and be ready to drop some loot if you hear that dreaded POP. its your car and your money... and you only die once!!!
my06tc
Jun 25, 2015 12:18 AM
sciontcguy15912
Apr 4, 2015 03:56 AM
TheRedBox
26
Nov 23, 2003 09:09 AM
