1st Gen xB electrical problem..Am I getting screwed?
Old Aug 10, 2007 | 09:40 PM
Archngl's Avatar
Default 1st Gen xB electrical problem..Am I getting screwed?
I had a few lights in my car go off (VSC, Track off), and so I did some research on here, and saw a bunch of people have the same issue... so I took my xB in (because It's still under warranty).
They told me that a rodent of some sort had chewed some wiring and it would need to be replaced. Error codes: C0205 and C1223 came up. They charged me 96.81.
They then proceeded to tell me it would cost 400.00 to fix. (They would not be replacing ALL the wiring, just the ones that are defective)
I asked them what wiring specifically, and they said, "until we get in there and look, we won't know for sure".
So... did I just pay for them to hook up my car to a computer and spew out a few error codes?
Also, I had someone have this exact problem with a Chrysler van, and it cost them a little over 100.00 to diagnose AND fix...
Discuss.
Old Aug 10, 2007 | 09:48 PM
06scioxb's Avatar
Team XcelsiA
Team Sushi
well if a rodent chewed some wire then you should try to verify... the computer will show the codes but not say oh a rodent chewed on this certin wire.... i say check for yourself i had those lights come on due to having too much oil in my intake filter so i eneded up cleaning the mass airflow sensor and problem went away
Old Aug 10, 2007 | 09:54 PM
Archngl's Avatar
They said they saw some wires chewed... So they did verify it by sight... but they didn't do a full diagnostic... So I do believe them on that part.
Old Aug 10, 2007 | 11:30 PM
xBster's Avatar
I'm always one to get a second opinion...but if rodents chewed the wires...well you may be out of luck and have to pay the price for a new harness or whatever they say needs replacing....
Old Aug 11, 2007 | 04:11 AM
ROBs-xB's Avatar
you should of just gone to auto zone,
they would have hooked up the computer
for free.
Old Aug 11, 2007 | 07:52 AM
bB2NER's Avatar
Music City Scions
If the dealer truely saw chewed wires they could have easily showed you them. If it's only a few lengths of wire they can splice and solder in new pieces no problem. Maybe 3 hrs of shop time. They should apply the diagnostic charges toward the repair bill also.
The whole repair should cost no more than a max of 300 bucks TOTAL with diagnostics included. Other wise since it's not covered under warranty. Take it to a place that specializes in auto electrics and get a better estimate or confirmation the the dealer wasn't trying to take you for a ride.
I suspect your dealer is not being truthful. It's prolly an easy fix and they just need an excuse for charging you more. my 2 cents.
Old Aug 12, 2007 | 03:00 AM
Archngl's Avatar
So, lets say I went in to the dealership to get my oil changed for 9.95 (Like I do every 3k miles) Would they have seen the lights during the tune-up and ran the diagnostic as part of the oil-change?
Old Aug 12, 2007 | 04:34 AM
jwaj2002's Avatar
TOCC
I took mine in for my CC not working abs light and a few others, they claimed I had a bunch of wires melted under the dash, well they charged me $60 after fixing, well when I paid and looked at the bill the only thing I saw on there was "replaced fuse, $60" and they had it in the shop for 3 freaking hours! for a frigging fuse, they claimed I made it blow, I asked how? by using the brakes?!
Old Aug 12, 2007 | 09:43 PM
Archngl's Avatar
Old Aug 16, 2007 | 11:51 PM
bigshrek's Avatar
you can buy your own diagnostic plug on ebay to see whats wrong for yourself
Old Aug 17, 2007 | 11:25 PM
Archngl's Avatar
Well, me and my dad fixed it in under an hour by soldering 2 wires together... everything's fine now... stil kinda ____ed they took me for 97 bucks.
Old Aug 18, 2007 | 06:01 AM
bB2NER's Avatar
Music City Scions
Look on the bright side. They charged you 97 bucks to let you know it was only a chewed wire. You saved whatever they wanted to steal from you to do the easy fix right? I say you still win and the stealership looses. Props on the fix it yourself Bro!
Old Aug 18, 2007 | 06:12 AM
jwaj2002's Avatar
TOCC
and you know its been fixed properly, some stealerships would have just taped it and moved on
Old Aug 18, 2007 | 06:14 AM
bB2NER's Avatar
Music City Scions
Good point! Forgot that.
Old Aug 18, 2007 | 02:50 PM
Archngl's Avatar
Absolutely... we took out the connector, cleaned it out, soldered and heat-wrapped the wires to make them water-tight.
It was done right.
effin' dealership.
Old Aug 18, 2007 | 08:44 PM
OldYeller's Avatar
All I can say is ----- RATS!!!
Old Aug 19, 2007 | 03:15 AM
jwaj2002's Avatar
TOCC
I bet those rats were about 5'8" with pocket knives and pliers, and wore toyota stealership work shirts
Old Aug 19, 2007 | 04:21 AM
daneisthegreatest's Avatar
took the words right out of my mouth...i can see a stealership doing that...
Old Aug 19, 2007 | 04:25 AM
jwaj2002's Avatar
TOCC
yep, me too, seen it before infact, a few have been busted for putting dirt and sand into diffs so they have to come back over and over for expensive NON WARRANTY repairs
Old Aug 19, 2007 | 05:57 AM
i know its off subject (kind of)...but i used to have a bagged s-10...and i loved getting oil changes in it at wal mart cuz i would set the frame on the ground and watch them walk around it for 10 minutes or so wondering how the heck i could even drive it...hahaha still brings a smile to my face...but back to my story......i went for an oil change one day and when i got home i noticed there was a lot of oil in my driveway, popped the hood and saw oil all around my head and down the block...well i took it to a mechanic and they said that someone filled it to the rim with oil (like 8 quarts or something) and he said when the pressure got up it had nowhere to go but out...wal mart never did anything, they actually told me they never saw that truck before in their life...so you better believe my beloved box will never be parked at the tire and lube express...ok i feel better now...lol...sorry for the long write up
