Avic D3 SUB ON & OFF Problem
Old Aug 11, 2007 | 02:41 PM
Night-Life's Avatar
Default Avic D3 SUB ON & OFF Problem
i just bought two 12 in" Memphis audio mojo subs, wired them down to 1 ohm stable with an 1800 w amp that handles 4-2-1 ohm's. the amps frequencies is tuned and the subs are also tuned from the equalizer, but i also want to tune it from the sub woofer menu. i noticed that you can turn the subs on and off from the avic d3 but the subs dont turn off when you select the off option so whats going on? i unplugged the rcas and checked to see if that option was for the speakers but they're not. also the d3 is bypassed for video play while driving but i dont think that has anything to do with it.
Old Aug 11, 2007 | 07:20 PM
blazeplacid's Avatar
make sure you have your RCA's pluged into the subout.
Also with the radio in "off" mode I belive you can go to your menu and on top it will say "initial" check to see if your radio is set to "rear speakers sub"
if so change it to sub woofer -preout or something like that.
are you useing a factory radio then using a hi/lo level converter? If so then you cant turn the subs off unless there is a function on the controller
if your confused just ask
Old Aug 11, 2007 | 07:27 PM
Night-Life's Avatar
not using a factory radio, and the rcas are plugged into the sub out leads. this things crazy.
Old Aug 11, 2007 | 07:39 PM
O5_TRD_tC's Avatar
check the remote wire.
Old Aug 11, 2007 | 09:24 PM
Night-Life's Avatar
found the problem, i double checked the rca and made a mistake. all three seta are the same set of rcas and i confused one with the other. my bad. thanx guys
mr_slim
Scion xD ICE & Interior
Jul 12, 2010 09:58 PM
getaforknjob
Scion tC 1G ICE & Interior
21
Aug 11, 2009 02:24 AM
scionsareok
Jan 31, 2009 11:46 PM
ack154
95
Jan 31, 2009 03:09 PM
1_kLEan_tC
15
Oct 23, 2008 08:05 PM
