hks ssqv not opening
Old Aug 11, 2007 | 06:31 PM
rozz-tC's Avatar
Default hks ssqv not opening
just installed my BOV, wont open though, im runnin 6psi.
I couldnt find any vac leaks or anything, from what I've read the ssqv is universal and isnt adjustable, is that correct?
Old Aug 11, 2007 | 06:38 PM
speedelement's Avatar
wut do u mean wont open? you need a large vacuum change to get the ssqv to completely open, try putting a boost gauge on the vacuum line to make sure there is a signal going to it?
Old Aug 11, 2007 | 06:40 PM
rozz-tC's Avatar
my boost gauge is hooked up off the same line coming from the TB, it shows boost and vac like normal, but even under full boost the ssqv wont open and discharge the air
Old Aug 11, 2007 | 06:49 PM
ouch... dunno about that. maybe try another vacuum source? have read that ssqv may require more powerful vacuum than a normal valve, but if its not opening at all...
Old Aug 12, 2007 | 03:44 AM
rozz-tC's Avatar
my car idles at about -22in/hg, which from what i've read is fine for the SSQV, i know abuncha tC's are running them.
Old Aug 12, 2007 | 07:27 PM
bash's Avatar
weird
Old Aug 12, 2007 | 07:30 PM
olaHalo's Avatar
Old Aug 12, 2007 | 08:04 PM
deathbyc4's Avatar
i thought my hks wasnt opening when i put mine on, but it turns out that the electronic throttle was making it flutter and not keeping consistent vacuum. try tapping into the manifold and not the throttle vac line.
Old Aug 13, 2007 | 12:57 AM
tonytc05's Avatar
Check the inline filter if it is installed backward.
Old Aug 14, 2007 | 05:21 AM
rozz-tC's Avatar
come to find out somehow the bolt in the back was gone, i never noticed/knew one should have been there since i've read they dont anymore, my is the older model...i stuck a bolt in there, gave it a few turns and it works like a charm.
SloTC1
Aug 16, 2018 02:45 PM
airmankevin1
Nov 17, 2015 05:44 AM
prescottn
Oct 8, 2015 05:31 PM
SoccerBoy_AP
Oct 1, 2015 06:28 AM
crimson_sinn
Sep 25, 2015 09:41 PM
