super noob question
Old Aug 12, 2007 | 02:47 AM
sciontc07's Avatar
Default super noob question
exactly without the big words what does the lower/higher compression ratio do? how does it affect things? =P thanks
Old Aug 12, 2007 | 03:48 AM
Zebman's Avatar
Compression = how much air is being forced into the engine.
High compression allows more fuel, meaning more power.
Low compression is the opposite.
High compression pistons are optimal for naturally aspirated engines, while low compression are good for turbo applications, since the turbo will be providing compression.
Old Aug 12, 2007 | 05:22 AM
sciontc07's Avatar
nice explaination...now
whats a good compression then?
sorry...
what does each number mean?
tC = 9:6:1
civic si = 11:0:1
which is better? so the tC is better to f/i ??
Old Aug 12, 2007 | 02:51 PM
dex's Avatar
dex
tC = 9:6:1
civic si = 11:0:1
it's a simple ratio...dont you remember high school math?
tC compression is 9.6:1, meaning the air/fuel mixture is compressed 9.6 parts to one. basically meaning that the volume at the top of the stroke could fit into the volume at the bottom of the stroke 9.6 times.
its hard to say which is better, there are alot of variables. with the tC your starting with more displacement (volume) at 2.4 liters to the civics 2.0 liters. and if you plan to go forced induction, your gunna be able to boost the lower compression tC motor more because your adding compression by compressing the air with a turbo/supercharger. in stock form the honda motor is much better. but just remember the aged old saying...there is no replacement to displacement.
Old Aug 12, 2007 | 04:02 PM
05FMXtC's Avatar
speaking of compression....i just did a compression test and got like a 190 on each...really dont no much about compression...i no as long as its consistent thats good...but is 190 what the tc should be?
Old Aug 13, 2007 | 02:33 AM
sciontc07's Avatar
ooo my apologies....it says 9.6:1
i thought it said 9 : 6 : 1
its nine point six!
Old Aug 13, 2007 | 05:07 AM
malibuboy54's Avatar
well general rule i've learned over the years, is lower compressions ratio equals better for f/i, while high compression ratios equals better for NA. If you have ever seen a truly great turbo car pushing crazy amounts of power, they always have a compressions ratio of 8.5:1 or near that......i call it the golden ratio, haha.....
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
