installing turbo!!! need help!!!!!!!
Old Aug 14, 2007 | 02:36 AM
JINeration's Avatar
Default installing turbo!!! need help!!!!!!!
i need help removing the oil pan!!!! need ideas
yes im working on my car this late only becuase its not over 100 degrees here in texas this late heheh
Old Aug 14, 2007 | 03:48 AM
yamaha16bw's Avatar
Blow torch.
Old Aug 14, 2007 | 04:51 AM
JINeration's Avatar
already tried but for how long ?
Old Aug 14, 2007 | 05:08 AM
krazykoo's Avatar
hey, what I did with mine was I used some thin blades and stuck them through, slowly chipping away the gasket material. After about half of the pan being chipped through, you can pry the pan open. Good luck!
Old Aug 14, 2007 | 05:16 AM
kikcaffine's Avatar
funny story, since mine came with an extra we just nailed mine 1 time with a mallot and it fell off, didnt mess up the pan at all either.
Old Aug 14, 2007 | 05:31 AM
JINeration's Avatar
anymore ideas ??? please
Old Aug 14, 2007 | 05:34 AM
kikcaffine's Avatar
Pry something under there and wedge it off, drain the oil first though!!! <- had to throw the idiot proof comment in there
Old Aug 14, 2007 | 05:57 AM
Mr_Meaty's Avatar
We just used a very short flat head screwdriver and the flat side of the hammer till it came loose. But i don't know if that damaged the pan, as we had a new one to install.
Someone else said a torch, which I had, but I was under there, looking at the flame right next to the hole where I removed the oil filter, and i was like "SCREW THAT!"
Old Aug 14, 2007 | 06:38 AM
JINeration's Avatar
yeah if onli i had an extra oil pan then i would prolly just hammer it off or something but i dont so i gotta be careful with this 1
Old Aug 14, 2007 | 06:40 AM
Mr_Meaty's Avatar
Dezod's instructions say what krazy said to do, and push small blades through to chip away at the sealant. Then hammer a flat head in to start prying it off.
Old Aug 14, 2007 | 07:16 AM
BuddhasTC's Avatar
when my s/c was put on...we torched the crap out of the oil pan and then banged the crap out of it and after about 15 minutes...it came off...okay maybe 30 minutes...it's a huge PITA!!
Old Aug 14, 2007 | 02:01 PM
brett561tc's Avatar
reach down between your legs, grab a fistfull of nuts, and realize that your a man. then put your mighty man strength into it, and make that toyota sealent your b!tch.
Old Aug 14, 2007 | 02:32 PM
Whocares05050's Avatar
haha. Yeah that sealent is somwthing serious.
Old Aug 14, 2007 | 03:42 PM
noskatana94's Avatar
I agree with dezod and krazy, use razor blades, thats what I did with mine, and it work like a charm. Or if you wanna be really lazy and spend another $100 bucks I can order you a pre-tapped S/C oil pan here from work and ship it to you.
Old Aug 14, 2007 | 03:44 PM
kikcaffine's Avatar
Guess im lucky that my oil pan just fell off then huh. lol
Old Aug 14, 2007 | 05:34 PM
malibuboy54's Avatar
here's a less than 10 min way to get it off......take your passenger side wheel off, so you can work through the wheel well.....get a blowtorch, like with propane, and sit there for about 2-3 min burning away the gasket.....then scrape away the stuff after its been burned off.....now take a large flat head screwdriver, i prefer a chisel, and a hammer, and give it a good 10-20 hard hits in the same place, make sure to stay flat when you're hitting the pan, as you can damage it.....one you get the seal broken, hammer in your flathead or chisel, and pry it open.....now for the propane, it has to be a real handheld tank, which would be about a foot long.....remember to take off the oil pan bolts and the oil filter, drain oil, etc! lol
Old Aug 21, 2007 | 11:49 PM
nychang65's Avatar
This is what we did.
Old Aug 22, 2007 | 02:02 PM
Rabid_Lemming's Avatar
Torch, and a small chisel worked well.
Old Aug 22, 2007 | 07:41 PM
Mr_Meaty's Avatar
OK, it's been a week. We need updates.
How did you get it off? Is the kit finished? How is it running?
Brammi
Nov 13, 2016 03:46 AM
my06tc
Jun 25, 2015 12:18 AM
Frustratez
Feb 26, 2015 04:03 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
