Umnitza Intake Question
Old Aug 14, 2007 | 04:42 AM
kikcaffine's Avatar
Default Umnitza Intake Question
Will the S/C run to lean with this intake? I know it will on others but I figured that since this is so short it shouldnt make a difference, am I right in this assumption or completly wrong? I also plan on getting an emanage blue in a bit here, should I just wait for the e-manage to put the intake on, im running a 9.5 pulley but not making over 7-8 psi at redline.
Old Aug 14, 2007 | 07:22 AM
BuddhasTC's Avatar
it will make u run lean...just not as much as a CAI would...unless this IS a CAI. But i would honestly recommend getting the Emanage, then the intake put on, and immediately get it tuned! Until i got mine tuned the first time with a similar setup...i was babying the hell out of the car because i was afraid to detonate the engine.
Old Aug 14, 2007 | 02:41 PM
kikcaffine's Avatar
Is basically a MAF adapter with a cone on the other end, its not a full CAI nor is it a SRI, its kinda like a pop charger
Old Aug 14, 2007 | 03:20 PM
BLUEMEANIE's Avatar
Team Hamster
I still don't get why a properly sized intake pipe with the maf located in the correct spot makes the s/c'ed tc run lean and a 9.5lb pulley with a stock intake doesn't.
Old Aug 14, 2007 | 03:35 PM
kikcaffine's Avatar
^ agreed
Old Aug 14, 2007 | 03:44 PM
krdshrk's Avatar
It shouldn't be too bad. Umnitza intake doesn't give much in the way of gains anyway.
Old Aug 14, 2007 | 03:45 PM
kikcaffine's Avatar
I just want the sound, thats the only reason I got it, LOL. Im tired of my car being so damn quiet
Old Aug 14, 2007 | 07:16 PM
BuddhasTC's Avatar
the pulley will make it run lean also...just nowhere as much as the CAI would
Old Aug 14, 2007 | 07:55 PM
BLUEMEANIE's Avatar
Team Hamster
If the pipe is too big or too small before or after the maf it would mess with the sensor, but why would a properly sized intake pipe with the maf located in the correct spot and the oem pulley make the s/c'ed tc run lean? ...or will it?
Old Aug 15, 2007 | 12:25 AM
Simplyscion's Avatar
Team No Limitz
it wont with the stock pulley, and a lot of cases it wont even on a 9.5 psi pulley if its properly setup...a lot of it is hearsay if you know what I mean
Old Aug 15, 2007 | 12:54 AM
jjos1's Avatar
I have been running perfectly fine with my cai and 9.5 pulley, I would think that any sri would not work as well as a full cai a/f wise.
Old Aug 15, 2007 | 01:50 AM
BLUEMEANIE's Avatar
Team Hamster
^^thats kinda what I figured... the ecu even with the trd tune is still adaptive, it's the improper pipe sizing that is messing with the maf sensor
^ thats good to hear. The voice of experience is where I'd put my money
Thanks for the feed back guys.
Old Aug 15, 2007 | 02:53 AM
kikcaffine's Avatar
^ Yea agreed!
Old Aug 15, 2007 | 05:59 AM
Complication's Avatar
Superchargers r ghay kikcaffine...I thought we had already discussed this. nucka.... J/P lol....
you can later.... I'll see ya at KSU
Old Aug 15, 2007 | 07:15 AM
BuddhasTC's Avatar
here's a dyno proven example of how lean the car is with 9 lb pulley and CAI...the pink/very top line, is my first dyno run with that setup with no tuning yet...even worse at the top because i had the stock injectors at the time
Old Aug 15, 2007 | 01:05 PM
BLUEMEANIE's Avatar
Team Hamster
So in that run you had the 9lb pulley, CAI and stock injectors?
Old Aug 15, 2007 | 02:47 PM
kikcaffine's Avatar
Why didnt you have the TRD injectors?
Old Aug 15, 2007 | 03:25 PM
BLUEMEANIE's Avatar
Team Hamster
^ correct me if I'm wrong but I believe he bought the kit used.
Old Aug 15, 2007 | 05:21 PM
kikcaffine's Avatar
Oh, well the stock injectors would certainly explain why the car would be running lean......
Old Aug 15, 2007 | 05:26 PM
kikcaffine's Avatar
