Type of spark plugs
Old Aug 14, 2007 | 04:43 PM
ABracy's Avatar
Default Type of spark plugs
I want to change my spark plugs. I have 95,000 miles on the current plugs. I went to the store to buy a set and the selecter stated that Autolite regular were OEM. So I found Autolite Platinum plugs for Scion XB 2004 and the gap was .044. I was browsing the internet and a site stated that the gap was .077-.079. Now I'm really confused so I called Toyota. The parts dept. guy told me that I should not used any other plug but theirs because it will damage the vehicle and further more, they did not use autolite plugs. Does anyone know the correct gap setting and can I use the plugs that I purchased?
Old Aug 14, 2007 | 04:49 PM
dugzilla's Avatar
You can use whatever plugs you want, it's not going to hurt the car.
Do a search, there are lots of thread on which sparkplug and what gap to run.
Factory is .044, but there is debate on whether or not you get better mileage if you open the gap a bit.
Old Aug 14, 2007 | 04:57 PM
ABracy's Avatar
Thanks!
Old Aug 15, 2007 | 01:17 AM
XbbbbBox's Avatar
Default Spark Plugs
I find the XB wears plugs more than any other vehicle I have had.
Last time I used NGK Platinum - $2.55 each from Rock Auto.com
NGK Part # 7090 {GP-Series #BKR5EGP}
{.032 gap}
I have had very good results with these plugs - last lot longer than standard plugs and reasonable price.
Old Aug 15, 2007 | 08:47 PM
eric_04scion's Avatar
i just put the bosch prolite platinum 4's on my 04 scion xa and put the gap at .077 and noticed a better start and better gas mileage. havent had anything go wrong yet.
Old Aug 19, 2007 | 06:29 AM
dirtyh2odog's Avatar
Default Re: Spark Plugs
{.032 gap}
I am using these same plugs and have great results as well...and for the price and effort it takes to change out the plugs, give them a shot and if you don't like it you are only out $10...but, I think you will like it...I had to adjust my gap down to .032 as they were set to about .042 out of the box, so make sure you check the gap- as you always should.
Old Aug 21, 2007 | 07:19 PM
dz302's Avatar
Just an interesting point I noticed while browsing the forum: Apparently the TC's have Denso iridium plugs from the factory.
Guess we couldn't get that lucky eh?
Seriously though: Scion states to change the plugs at 30k intervals. Is this by and large what folks are doing?
Old Aug 21, 2007 | 07:21 PM
hotbox05's Avatar
ngk iridium IK 9
Old Aug 22, 2007 | 07:48 PM
HeathenBrewing's Avatar
I was curious as to the condition of my plugs @ 16K mi. Since I took the time and pulled them out, I figured why reinstall the old ones? Of course the old plugs looked almost new, but @ $8.00, they were too cheap not to replace. Replace > Reuse IMO.
I put in 4 new OEM Denso K16R–U.
Old Aug 23, 2007 | 01:08 AM
ABracy's Avatar
Does anyone know exactly how the spark plug works in terms of the gap? I mean if you open the gap more what actually happens? If you close it what results will you get?
Old Aug 23, 2007 | 01:52 PM
A narrow gap may give too small and weak a spark to effectively ignite the fuel-air mixture, while a gap which is too wide may be too wide for a spark to fire at all. Either way, a spark which only intermittently fails to ignite the fuel-air mixture may not be noticeable directly, but will show up as a reduction in the engine's power and fuel efficiency.
As the plug ages and the metal of the tip erodes, the gap will tend to widen; therefore experienced mechanics often set the gap on a set of new plugs at the engine manufacturer's minimum recommended gap rather than in the center of the specified acceptable range, to ensure longer life between plug changes. On the other hand, since a larger gap gives a "hotter" or "fatter" spark and more reliable ignition of the fuel-air mixture, and since a new plug with sharp edges on the center electrode will spark more reliably than an older, eroded plug, experienced mechanics also realize that the maximum gap specified by the engine manufacturer is the largest which will spark reliably even with old plugs and will in fact be a bit narrower than necessary to ensure sparking with new plugs; therefore, it is possible to set the plugs to an extremely wide gap for more reliable ignition in high performance applications, at the cost of having to replace and/or regap the plugs much more frequently, as soon as the tip begins to erode.
Old Aug 28, 2007 | 12:01 PM
ABracy's Avatar
Cool. Thanks. You put that very well!
Old Aug 28, 2007 | 12:04 PM
jallamas's Avatar
Nice info!
Thanks
John
Old Sep 9, 2007 | 05:49 PM
Reiji_Dorifuta's Avatar
Hmm... take the minimal gap and add .010, maybe?
Old Sep 10, 2007 | 06:10 PM
Sciond's Avatar
at 28,000 miles I put in the Denso Irridiums...and never looked back..I have 72,XXX on the box now... I should go 50,000 more miles or so before I touch them again
RY_TC07
Jul 18, 2017 05:18 PM
kleecker
Jul 11, 2015 09:39 PM
my06tc
Jun 25, 2015 12:18 AM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
eric_m
79
Mar 17, 2013 12:21 AM
