2008 xB short ram intake with Randode MAF adapter
Old Aug 14, 2007 | 04:49 PM
n2htwlz's Avatar
Scion Apocalypse
Default 2008 xB short ram intake with Randode MAF adapter
Here are pics of the VRD short ram 05-06 tC intake with the Randode Maf adapter installed on our 08 xB.
Old Aug 15, 2007 | 01:00 AM
Boxer_Rebellion's Avatar
That's exactly what I was waiting to see done... looks great!
Old Aug 15, 2007 | 07:55 PM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
Very nice! Did everything just bolt right up? Had to make anything? Brackets? Feel a difference?
Old Aug 15, 2007 | 08:14 PM
n2htwlz's Avatar
Scion Apocalypse
Need to make 1 bracket, real simple tho. There is a bit more performance and it is louder too.
Old Aug 15, 2007 | 08:22 PM
KevinTxB's Avatar
it makes the engine louder or the exhaust? do you have the trd exhaust?
Old Aug 15, 2007 | 08:37 PM
n2htwlz's Avatar
Scion Apocalypse
Custom dual exhaust but its gonna make the engine louder because of the removal of the air box.
Old Aug 15, 2007 | 08:48 PM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
Is that the bracket on the left hand side of the 3rd pic?
Old Aug 15, 2007 | 09:08 PM
n2htwlz's Avatar
Scion Apocalypse
No, its actually the bracket under the small round rubber insulator on the underside of the intale. The bracket you mentioned comes with the kit.
Check this bracket out, See link here ---> http://www.scionapocalypse.com/forum...hp?p=5011#5011
Old Aug 17, 2007 | 01:15 PM
cincinfocal's Avatar
ona side note...i have a question about the stock intake..there is this second filter layer...this carbon or whatever insert...thats permanent in the box...there is no emissions issue with removing that? i have to read again but i thought i read something where that should not be removed...
Old Aug 17, 2007 | 01:23 PM
n2htwlz's Avatar
Scion Apocalypse
If your worried about it then buy a drop in TRD or K&N filter and be done. The second layer is probably for sound resonance or has to do with squeazing out a bit more mileage but I will ask around to see what it is.
Old Aug 17, 2007 | 01:58 PM
the thing is that i want an pipe intake...not this stock box..but yeah...dont know if that thing is mandatory in there for the life of the vehicle...
Old Aug 17, 2007 | 02:32 PM
n2htwlz's Avatar
Scion Apocalypse
The whole box gets removed even if you install the TRD cold air intake too
Old Aug 17, 2007 | 02:35 PM
ok..cool...gonan do the short ram set up now :D with the old tc :D nice! thanks n2htwlz
Old Aug 17, 2007 | 02:51 PM
is this the intake you got? http://cgi.ebay.com/ebaymotors/04-05...7138QQtcZphoto
Old Aug 17, 2007 | 03:37 PM
n2htwlz's Avatar
Scion Apocalypse
Similar but basicaly the same intake.
Old Aug 19, 2007 | 04:03 PM
matt311's Avatar
looks good .. BUT your not getting cool air from right there... where that is located .. that is where the hottest air comes from the engine on the new xB....
Old Aug 20, 2007 | 10:46 AM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
A short ram intake is not made to pull in cold air. You will only get that from a cold air intake. A short ram is designed to pull air in more quickly. Gains are roughly about the same between the two, just all depends on what look you rather.
Old Aug 20, 2007 | 01:17 PM
n2htwlz's Avatar
Scion Apocalypse
Great answer .
I like the short ram intakes better anyways, in my opinion .
Old Aug 20, 2007 | 02:00 PM
matt311's Avatar
I guess it is more about look.. because it dosnt seem as if it would pull in air much faster just b/c its shorter... but oh well.. looks nice...
Old Aug 20, 2007 | 05:58 PM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
Deff pulls air in faster, less of a strain on the engine, less turns and bends to go through.
Example, take a straw, put it in your mouth and the other in a cup of water and suck in really fast.
Now take about 5 straws, make one really long straw with them put it in a cup of water and suck in, which one is easier?
The shorter one.
