MikeInABox
08-15-2007, 06:52 AM
I call this an improvement because it takes the hose attached to the airbox out of the engine bay and down lower to cooler air. It will probably be better for those that want to stick with the stock airbox and a hi-flow drop in filter. It's not pretty (really not noticible visually) and it's not gonna give hp/tq increases. But it's free right? So what the hell.
I got this idea from my VW days. One of the easiest things to do was rip off restrictive stuff underneath the airbox to help airflow. Many people added rubber ducting hose that ran from the airbox down to the bumper. So I started looking at what was under the airbox on my xB and was surprised to see it had ducting that went down and curved back up into the engine bay. So my brain started working (for once LOL) and here's what I did.
Oh, and I apologize for some of the pics not being so great.
Disclamer: Do this at your own risk! I'm not responsible if you do this and problems arise as a result. And as always, be careful when working under a jacked up car!
Tools you need:
Jack
Small Flat Head Screw Driver
10mm Socket
Jack the car up and take off the front drivers side wheel
Here's the top behind/under the headlight. The hose comes off the airbox, goes down behind the bumper, then loops back up and the open end is on top of where starts by the airbox. Sorry this pic is the suck.
http://i69.photobucket.com/albums/i73/TurboMoe/Stocktube.jpg
First thing to do is use a flat head screw driver to pop the plastic rivet off this bracket:
http://i69.photobucket.com/albums/i73/TurboMoe/TopRivet.jpg
I just pulled up and the top snorkle/tube/whatever pulled right out and off the hose. Here's what it looks like:
http://i69.photobucket.com/albums/i73/TurboMoe/Horn.jpg
Next use the 10mm socket and take this bolt out. It's kind of tight down there:
http://i69.photobucket.com/albums/i73/TurboMoe/TopBolt.jpg
That will free up the top part of the hose, so move to the bottom.
Underneath the driver side corner, use the 10mm socket to remove the two screws, and use the flat head screw driver to pop the plastic rivet off:
http://i69.photobucket.com/albums/i73/TurboMoe/Corner.jpg
Then move to the fender liner. I just loosened the front section and it pulls away plenty far to get to the hose. Use the flat head screw driver and turn the lower left rivet thing. You'll hear a pop and it should pull right out. I've never seen one like this before, kinda neat. And the one rivet in the middle is pointing straight up, you can't see it in the pic, but the middle arrow is pointing to it.http://i69.photobucket.com/albums/i73/TurboMoe/Liner.jpg
After that you can pull the fender liner back and here's what you should see:
http://i69.photobucket.com/albums/i73/TurboMoe/Stockhose.jpg
Use the flat head screw driver to pop this rivet out:
http://i69.photobucket.com/albums/i73/TurboMoe/HoseRivet.jpg
The hose will be free and you can pull it down from the top:
http://i69.photobucket.com/albums/i73/TurboMoe/Hose.jpg
You can place the hose end where ever you like. I put it as far forward as I could. I zip tied it to the foglight harness (I assume that's what it is, just a bundled wire with a plug that goes nowhere). That placed the end pretty close to the lower grill:
http://i69.photobucket.com/albums/i73/TurboMoe/ZipTie.jpg
http://i69.photobucket.com/albums/i73/TurboMoe/Grill.jpg
That's it!
Just re-install everything the way it came apart. I give mad props to Toyota for the design of their plastic rivet things. They're so easy to remove and put back in. I'm used to the VW ones which have to be destroyed to remove lol.
With this of course there is the question that if it could suck up water and hydrolock, like with CAI's. Anything is possible I suppose, and it depends on where you put the end of the hose. Even then it will have to make it up the hose and through the still restrictive airbox/filter. Still I guess that's a threat.
Just wanted to share this with the community. Hope maybe someone will find it helpful in some way. I figured it's free and easy, so it can't hurt to share.
Thanks,
Mike
Tools you need:
Jack
10mm Socket
That's it!
Thanks,
Mike
