Suspension related questions..
Old Oct 12, 2004 | 03:05 AM
pfunk's Avatar
Default Suspension related questions..
Hey everybody I am pretty new round here. I just got my xB from a guy who already did some mods to it. It has TRD shocks and struts but I would like to lower bit more. Can I use another set of springs with the TRD struts? I don't want to mess the shocks. I have a set of stock ones too. next question. My other car is Mini Cooper S and even though xB probably won't handle like Mini does but I would like it to be little more focused in handling. Rear say bar made a huge difference in handling for my Mini and I think I want to put one on xB as well. I see Hochikis selling the F&R set but is there a company that sells rear sway bar only? I think front sway on a FF car doesn't make that much difference in eliminate under-steer. And lastly who is the scion guru in SOCAL? where should I take my xB for all the mods?
Thanks in advance and good to join another car nut group!
Old Oct 12, 2004 | 07:56 AM
Minsk99's Avatar
Progress just came out with a 22mm rear sway for the xB/xA. Selling for $149. Here is a link to a Scion Life sponsor that is selling it:
https://www.scionlife.com/forums/viewtopic.php?t=29696
Old Oct 14, 2004 | 07:35 AM
LeeD's Avatar
Default Re: Suspension related questions..
[quote="pfunk"]Rear say bar made a huge difference in handling for my Mini and I think I want to put one on xB as well. I see Hochikis selling the F&R set but is there a company that sells rear sway bar only? I think front sway on a FF car doesn't make that much difference in eliminate under-steer. quote]
Your absolutely right.
These cars are naturally front weight biased, therefore will naturally understeer if give the same modifications of a front engine/rear drive car. For front engine/front drive cars you need to go down a different handling modification path.
I totally agree that these cars only need a rear swaybar to improve the handling. Only once you can get the car to oversteer, might you need a front swaybar, even with suspesion mods. Untill then, I don't think there will be much handling improvement with a front sway bar. You need to get the balance right.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
SloTC1
Aug 16, 2018 02:45 PM
prescottn
Sep 22, 2015 01:30 PM
Subaru86
Sep 14, 2015 12:51 PM
prescottn
Sep 13, 2015 09:04 PM
