Any Dremel Masters?
Old Aug 19, 2007 | 01:20 AM
STNC's Avatar
Default Any Dremel Masters?
Is there anyone here that would be willing to cut out the S C I O N part of the front emblem for the tC? I tried, and i messed it up. Has anyone done this before? I know its been done for the rear emblem. I want to light it up!
Old Aug 19, 2007 | 03:15 AM
Fhe1079's Avatar
You can try drilling small holes to fit fiber optic wire in it to make the effect you need. That way there is a easy way to fill it in if you mess up.
Old Aug 19, 2007 | 04:47 AM
BZinn1's Avatar
Use a very small cutting bit for the dremel and take your time....it is the bit that has the cutting ball at the tip.......about 3 hours to do it right at worst..........use a flexable tip for the dremel so you are not having to hold the dremel and cut.
Old Aug 21, 2007 | 10:00 PM
U-S-S-TC1701's Avatar
I'm the one that did the emblem for the rear. I used the drill bit used for cutting holes in dry wall. I tried using the bit that has the cutting ball on the top, but I was to big. The drill bit is very small. About the thickness of a dime. Just take your time, Thats one of the problems I ran into on the first emblem, when I tried to rush throw. If you screw up you can always buy another emblem and try again and again
Old Aug 21, 2007 | 10:15 PM
STNC's Avatar
Your my idol for this project!
yhwhdesign
Jun 11, 2021 03:34 PM
StxArOne
Scion xA Aero & Exterior
Aug 21, 2015 06:44 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
Dapitt84
Mar 4, 2015 02:03 AM
