OK who's runnin 18x8's
Old Aug 22, 2007 | 04:29 AM
Cyrus's Avatar
ScionERA
Default OK who's runnin 18x8's
I really need some feedback on this
The rims I want in an 18 only come in an 8" wide rim, I can get the offset from 32 to a 45. I want to run 40's for sidewall and ride. If an 8" is gonna rub badly then I will have resort to 17's as these come in 7.5" wide and then run 45's for ride and to fill the wheel well.
Lookin for some feedback here ya'll ! ! !
Old Aug 22, 2007 | 04:31 AM
MattyRattyPoo's Avatar
Depending on how low you are, you should usually run 35 series for 18's and 40 series for 17's.
Old Aug 22, 2007 | 04:32 AM
scion_jon's Avatar
WHEEL FITMENT INFORMATION
It is assumed that these figures will work on both the xA and the xB, but most are from xB owner's personal comments.
WHEEL SIZE . . OFFSET RANGE . . TIRE SIZES . . . COMMENTS
19x8.0 . . . . . . . 35 (Front)25(Rear)215/35/19 . . . . Rubs Slightly XB(shim kit)DenZinz
19x8.0 . . . . . . . 40 . . . . . . . . . . . . . 215/35-19 . . . . Rubs under hard cornering
19x7.5 . . . . . . . 45 . . . . . . . . . . . . . 215/35-19 . . . . Rear needs 5mm spacer: DGTLLVR
19x7.5 . . . . . . . 42 . . . . . . . . . . . . . 215/35-19 . . . . No rubbing, rear mud flap trimmed: gregp909
19x7.0 . . . . . . . 42 . . . . . . . . . . . . . 215/35-19 . . . . Rolled fenders & hammered wheelwell: matchbox
18x7.0 . . . . . . . 28-32 . . . . . . . . . . 215/35-18 . . . .foxSCION "no rubbing"
18x7.0 . . . . . . . 40 . . . . . . . . . . . . . 235/35-18 . . . .K4kas no rubbing xB
18x7.5 . . . . . . . 35 . . . . . . . . . . . . . 215/35-18 . . . .Front tire rubs at full lock
18x7.5 . . . . . . . 35-42 . . . . . . . . . . 215/35-18 . . . .Silkywilson et42
18x7.5 . . . . . . . 42(Front)(35)Rear 225/35-18 . . . .Oneslowxa 2"drop tanabe sustec pro
18x8.0 . . . . . . . 28 . . . . . . . . . . . . . 225/35-18
18x8.5 . . . . . . . 28 . . . . . . . . . . . . . 225/35-18
18x9.0 . . . . . . . 31 . . . . . . . . . . . . . 225/40-18 . . . .rampagesd
17X7.0 . . . . . . . 20 . . . . . . . . . . . . . 205/40-17 . . . .quadoptix xB
17x7.0 . . . . . . . 28-42 . . . . . . . . . . 205/40-17
17x7.0 . . . . . . . 40 . . . . . . . . . . . . . 215/40-17 . . . . .TheScionicMan
17x7.0 . . . . . . . 38 . . . . . . . . . . . . . 215/45-17 . . . . xB stock
17x7.5 . . . . . . . 30-40 . . . . . . . . . . 215/40-17 . . . .
17x7.5 . . . . . . . 40 . . . . . . . . . . . . . 215/40-17 . . . .3mm Spacers CBSIMONSEZ xB
17x7.5 . . . . . . . 38 . . . . . . . . . . . . . 215/40-17 . . . .Stock xA Leinad
17x8.5 . . . . . . . 16 . . . . . . . . . . . . . 215/40-17 . . . . Front doesn't rub: Oper8r
17x9.0 . . . . . . . 17 . . . . . . . . . . . . . 215/40-17 . . . . Rear rollled fenders: Oper8r
16x7.0 . . . . . . . 33 . . . . . . . . . . . . . 205/55-16 . . . . Front rubs slightly in front: oj411
16x7.0 . . . . . . . . . . . . . . . . . . . . 205/55-16 . . . . No rubs: The Zeeness
16X7.0 . . . . . . . 35 . . . . . . . . . . . . . 205/45-16 . . . . Stock xB: Pushytop
16x7.0 . . . . . . . 25-35 . . . . . . . . . . 205/40-16
16x7.5 . . . . . . . 38-40 . . . . . . . . . . 215/40-16
15x6.5 . . . . . . 35 . . . . . . . . . . . . . 185/60R15 or 185/65R15 (xB and bB stock sizes)
15x7.0 . . . . . . 38 . . . . . . . . . . . . . 185/60-15 . . . . Stock Size xB
15x8.0 . . . . . . 18(Rear)23(Front) 205/60/15 2" ground control Minsk99 xB
Old Aug 31, 2007 | 08:56 AM
DaToaster's Avatar
dude get 35 but dont strech cause when u do its like running on 25-30
btownTC
Scion tC 1G Wheel & Tire
20
Mar 21, 2006 02:29 PM
deejaytnk
11
Feb 13, 2006 02:55 AM
daewonder
Regional - Islands
Jan 8, 2006 09:32 PM
thefoth
26
Feb 17, 2004 10:41 AM
