lightweight crank pully
Old Aug 22, 2007 | 09:06 PM
2007_wichitaSCION's Avatar
Default lightweight crank pully
This may be somewhere else in the forums, but i couldnt find it anywhere.... so.... the question is, would installing a light weight crank pully do any good for a stock tc with header and exhaust upgrades or would it just be a waste of money in terms of improvement?
One more thing, its not about a crank pully but the grounding kit, could someone tell me a little bit more about it and its benifits?
I would appreciate this greatly
Old Aug 22, 2007 | 09:09 PM
TeeCizzle's Avatar
Yea if ur Not planning on Boost'in or S/C the Crank Pulley is good for i/h/e
I dunno about Power Gains!..theres a 50/50 deabte about that!!!
I am still waiting to get mine Installed!!!!!...
Negative about knowing anything about grounding Kits...lol
Old Aug 22, 2007 | 09:11 PM
equinox2355's Avatar
with a good search you can find the answers to your question.
as far as the crank pulley goes, there are people that say it is ok, and people that say it isnt. I am from the school of thought that it is bad for the motor. Mainly because I had a crank bearing problem without even having one of these pulleys. It puts more stress on the crank and has a harmonic resonance that will cause problems. I would not recommend the lightweight crank pulley to anyone.
I say its not worth it to risk your motor, but your choice, and this is just my opinion.
As for the grounding kits, ive not done a lot of research, but some people swear by them and others swear AT them
Old Aug 23, 2007 | 02:01 AM
GenericUserName's Avatar
just installed my agancy power lightweight crank
not a huge gain but def. notice the diff from 30-40
and from 50,55 to 65
Old Aug 23, 2007 | 03:33 AM
TeeCizzle's Avatar
did u use an air gun??....if Not how & what did u use?
was it pretty easy 2 install...like the belts n stuff dont get screwed up??
i have the Agency too!...
Old Aug 23, 2007 | 03:40 AM
07tctul's Avatar
X2
My friend has a 2006 subaru 2.5i and the motor started knocking and then just went up in smoke. He found out that it had something to do with the agency crank pulley he installed. So if u are unsure about how safe it is, it is better not to do it.
Old Aug 25, 2007 | 08:48 AM
yea i used an air gun
had to get a 3 jaw pulley puller but 2 jay may work
took about 15 minutes
i actually had my mom pull on the tension bolt for me lol
the rear sway bar was much harder to install than this
Old Aug 26, 2007 | 11:13 PM
soros151's Avatar
X2
Maybe he screwed with something else during the install...
Old Aug 26, 2007 | 11:23 PM
Zebman's Avatar
X2
Actually, i'm willing to bet his oil pump failed from vibrations the pulley caused.
Old Aug 27, 2007 | 12:13 AM
soros151's Avatar
X2
Well, point is no one has complaint about ANYTHING on the tCs, and there is still not enough proof about crank pulley damage. Just hear-say about it.
Old Aug 27, 2007 | 12:16 AM
Menace's Avatar
X3
You do not want compromise the longevity of your engine. While we have an internal balancer, the torsional damper eliminates the resonance. With out it you are subject to potential damage to the bottom end. To each is own, and a lot of people swear by pulleys, but I would not compromise my engine. Just add a light weight flywheel and you will feel almost the same gains with out compromising anything.
Old Dec 3, 2007 | 12:49 AM
mengsta's Avatar
so whichitascion did u finally get the pulley? just curious about this old thread.. So are so many topics where the OP nvr follows thru. In fact i installed mine with 1 friend and basic hand tools. Cranked the engine to get the pulley off. easy peazy. And "genericusername" if you are still watching y da hell did u need a jaw pulley puller? Once u pull ont he belt tensioner bolt the pulley can come right out. lol
Old Dec 3, 2007 | 02:57 PM
2azfeboost's Avatar
wow u totally messed up on the install. u skipped vital steps. better re-do it RIGHT
Old Dec 4, 2007 | 02:26 AM
mengsta's Avatar
I would greatly appreciate it if you told me the vital steps please. Not trying to sound smart i would like to know. I read the dIY on the lightweight ZPi pulley which is the same thing because of the Oem sizing.
Old Dec 4, 2007 | 02:53 AM
SVicksTC's Avatar
ITs very easy there is a tensior bolt inbetween all the pulleys you put a 19mm socket on it and pull forward this realease the tension on the belt and you swap out the pulleys then realese the bolt to put tension back on the pulley's, two man job one pulling the bolt one putting the pulley on, def. use a airgun to put the pulley bolt back in and thats all there is to it
Old Dec 5, 2007 | 12:26 AM
BrEaK_AwaY's Avatar
keep your stock pulley. dont waste your money on a a/m light weight crank pulley... it will catch up to you in the long run.
as far as a grounding kit, it wont help you for anything. are you running a massive system? if so i would hope you, or whoever installed in knew how to ground it right
Old Dec 5, 2007 | 03:07 AM
mengsta's Avatar
So 2azfeboost?now im starting to think you are just trying to sound smart becuz u still didnt tell me how i did it wrong. Yes I had a friend to pull the tensioner bolt. Thanks Svicks. It was very easy and i think i am probably the only one on this forum that did it with only wrenches. When i screwed it back in , i added a touch of loctite blue. and there you go. I rechecked and thePulley is still on and does not move side to side. So please tell me how i Totally messed up.
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
CrowJenkins
Oct 9, 2015 10:47 PM
Topfueltom69
Sep 6, 2015 05:25 PM
xjleitex15
Aug 18, 2015 01:23 AM
