Tsudo 4-2-1 Header installed!! on a Supercharged tC!!
Old Aug 23, 2007 | 12:20 AM
TongMan's Avatar
Default Tsudo 4-2-1 Header installed!! on a Supercharged tC!!
Okay, I got the header and s-pipe installed. Happy about that. BUT, the s-pipe is such a problem. It won't fit with the mid-pipe. I had to force it to align. It was a big fitment issue. Putting the header in was also F-ing difficult. I had to move the transmission lines and the oil line from the supercharger to make the header fit in. I finally got it in, but there was another thing. You can see for yourself...
Old Aug 23, 2007 | 12:25 AM
KINGxOFxSKA's Avatar
Unique Scionikz
Default Re: Help! I need to get this nut out!
If you're looking for assistance, I'd suggest finding a girl.
Old Aug 23, 2007 | 12:39 AM
TongMan's Avatar
okay...some help please. what tool do i need?
Old Aug 23, 2007 | 12:44 AM
jaxtcracer's Avatar
post a pic of your specific application and we might be able to give you better suggestions
Old Aug 23, 2007 | 12:48 AM
Unique Scionikz
If I remember correctly, I used a flexible ratchet head.
Something like this:
Old Aug 23, 2007 | 12:58 AM
TongMan's Avatar
i don't think those will fit...cause the alternator is in the way and those heads won't fit.
Old Aug 23, 2007 | 01:08 AM
GammaTNT's Avatar
copy from my other post.
I was careless and I rounded one of corner with cheap wrench , i was trying to take the alternator too. but after loosen the belt tensioner and the big bolt off. There is a little bolt that i have no room to get too.
having a nice set of wrenchs is important
I found another combination wrench in my house. I use the box end side.
i took some pic to help u. This pic is taking after i install the dc header. It was very hard to place the wrench when the stock header was there.
I hammer a pipe to to the wrench. Making sure it is in and won't round corner.
With Someone pushing the pipe to the wrench,
Now u can hammer the wrench .
Old Aug 23, 2007 | 01:46 AM
TongMan's Avatar
Yeah it's kinda hard for me to do that cuz the supercharger is in the way. It's a really tight squeeze.
Here are some pics.
Old Aug 23, 2007 | 02:04 AM
TongMan's Avatar
Okay. I got that damn stock header out! DAMMIT!!!
Now I have to put that new header in. I won't fit!! Do I have to take out the Radiator?
Old Aug 23, 2007 | 06:54 AM
TongMan's Avatar
Updated...please check..
Old Aug 23, 2007 | 07:10 AM
TcPrincess's Avatar
hey man where in EG are you? maybe i can drop by and give you a hand.
Old Aug 23, 2007 | 07:19 AM
TongMan's Avatar
Yep. I definitely needed some help because it was my first header install. took me 8 hours to finish. The bung for the o2 sensor won't fit so I am going to request for a different s-pipe.
Old Aug 23, 2007 | 08:22 AM
TcPrincess's Avatar
hey did you run the s-pipe over the axle? its supposed to go over the sub frame and under the axle iirc. maybe thats why it didn't line up.
Old Aug 23, 2007 | 08:31 AM
whitetrd's Avatar
8 hours? oh my
Old Aug 23, 2007 | 08:37 AM
BuddhasTC's Avatar
you can also remove just the shaft of the s/c and the pulley end of it so that it will be a little easier to put that header on
Old Aug 23, 2007 | 01:13 PM
Fsu1dolfan's Avatar
Sorry to hear it took you so long man.....yeah the supercharger makes it a real b!tch!
But the header looks nice and other than the s-pipe problem should be GREAT.
Keep us updated and thanks for the pics!!
Old Aug 23, 2007 | 04:04 PM
Sleep3r's Avatar
that s-pipe problem sucks man. these are the MMW replicas right?? maybe they should have copied it better so there wouldn't be any fitment issues. hope it works out for you or they send you another spipe
Old Aug 23, 2007 | 04:07 PM
Fsu1dolfan's Avatar
He just needs the MMW L Bracket for the s pipe....probably the reason MMW fabricated that anti fouler that way
Old Aug 23, 2007 | 05:48 PM
MysTiKchRis's Avatar
TONG you NUBE =)
Old Aug 23, 2007 | 06:45 PM
m6ar2cel6oTC's Avatar
ok since you got it on now? hows does your car feel? any different? hows it sound? any rasp? what exhuast set up do you have? sorry so much questions cause i am debatong on the header or the mazzuri one?
