CEL returns!!!
Old Aug 26, 2007 | 02:40 AM
insanezane's Avatar
Default CEL returns!!!
it returned after about 50 miles...
i got a megan header along with the spacer for the O2 sensor...how do i get it back off? can i just put some washers on the O2 to space it farther away from the s-pipe? or find a longer spacer? or what?
Old Aug 28, 2007 | 07:24 PM
SandMPerformance's Avatar
ok, first, did you put the CEL eliminator on the second O2 sensor? second, have you checked to make sure its a cat or O2 code?
Old Aug 29, 2007 | 02:27 AM
insanezane's Avatar
yeah its on the second one...and no i havent checked the code...
Old Aug 29, 2007 | 08:04 AM
Sleep3r's Avatar
it seems like megan is the hardest header to maintain CEL free. try using the 3 antifouler trick.
Old Aug 29, 2007 | 01:44 PM
insanezane's Avatar
what do you mean? just got 3 of them and link them together?
Old Aug 29, 2007 | 03:33 PM
Sleep3r's Avatar
yes. the normal mod is 2 antifoulers with most headers but with megan i been reading that it takes 3 for it to work. the o2 sticks out further from the spipe not reading less airflow i suppose. try it the foulers are cheap anyway
Old Aug 29, 2007 | 04:55 PM
insanezane's Avatar
cool i will try that
Old Aug 29, 2007 | 05:05 PM
iKONA's Avatar
So what is it? You just put washers under the 02 censors and thats it? a few pennies? Im having the same problem and Im new to this.
Old Aug 29, 2007 | 05:21 PM
iKONA's Avatar
Since I'm new to all this I forgot to ask. Will after market headers over a period of time ruin the catalytic converter? I thin I got the name rite.
Old Aug 29, 2007 | 05:34 PM
Sleep3r's Avatar
There is a thread for this!
search for "antifouler"
they are not just washers
go to your local auto parts store and pick up the HELP BRAND sparkplug foulers #42002 i believe and megan needs 3. you also need a 1/2 inch drill bit to drill a hole out of one
i forgot but i think it goes like this
o2 bung ----> modded antifouler ----> un-modded antifouler ---> o2 sensor
Old Sep 1, 2007 | 12:12 AM
or, there are companies that sell them especially for types of cars.
Old Sep 1, 2007 | 12:30 AM
Mid_Life_tC-risis's Avatar
Not that I've heard of. Cats are ruined by the engine running too rich and exhausting unburned fuel out the combustion chamber and into the cat. The cat will then burn the fuel and melt its internals. This malfunction can happen whether you have aftermarket parts or stay completely stock.
Wouldn't worry about it though. If the engine runs too rich (or too lean, which is actually worse) the ECU will tell you by generating a CEL.
Old Sep 1, 2007 | 03:21 AM
aftermarket headers eliminate the cat.... (on the tc)
Old Sep 1, 2007 | 02:03 PM
The stock tC has 2 cats, one in the exhaust manifold (pre-cat) and one in the midpipe (main cat). A header deletes only the pre-cat.
Old Sep 1, 2007 | 02:45 PM
Zebman's Avatar
It's the other way around I believe.
Old Sep 1, 2007 | 03:18 PM
Some vehicles employ a pre-converter in the exhaust system immediately after the manifold to help during this warm-up period. The pre-converter’s small size and proximity to the engine allow it to heat up and start functioning in less time than the main converter. It also pre-heats the exhaust gasses and helps the main converter reach operating temperature sooner.
click for converter basics
Toyota does this to meet ULEV specs. Our two cats are the three-way type btw.
Old Sep 1, 2007 | 03:20 PM
Sleep3r's Avatar
^^ thats what i was thinking, the one on the mid is just a small little cat
Old Sep 1, 2007 | 08:01 PM
umm... isnt it just a main cat and then a resonator.... a cat would be identified by two o2 sensors (one before and one after).. this way the ecm can monitor if it is working.... if so... whether the second cat goes bad or not, the ecm would never know.
Old Sep 1, 2007 | 08:34 PM
Yes, the stock midpipe consists of the main cat and resonator. The main cat is not monitored with sensors.
Only the pre-cat in the exhaust manifold is monitored. The pre-cat is located much closer to the combustion chamber than the main cat, so it will run hotter and would be first to be exposed to any unburned fuel that enters into the exhaust stream. So this cat is more likely to fail.
I would expect that on any car diagnosed with a failed pre-cat, the Toyota mechanic would also inspect the main cat.
Old Sep 3, 2007 | 05:37 AM
mcclone's Avatar
I have a megan header too. If you haven't solved your cel problem. go to auto zone get a package of doorman 18mm anti foulers. Drill one out with half inch bit, you will need a drill press or titanium bit if your are going to hand drill. Put the o2 sensor in the drilled one then screw the other not drilled one one and the reinstall. That should take care of your cel.
yupinmytC
22
Jul 27, 2024 07:08 PM
SloTC1
Aug 16, 2018 02:45 PM
Blunderbuss
Oct 8, 2015 04:56 PM
MeDizzy
Oct 8, 2015 03:31 PM
paisatronix
Sep 5, 2015 04:13 AM
