View Full Version : need Headlight help
coregmrconman
08-27-2007, 01:32 AM
does anyone know if 9006 hids will work with these
http://i162.photobucket.com/albums/t251/toyotabb-strudel/headlightsforsale.003.jpg
thanks all.
low_down_xb
08-27-2007, 02:07 AM
i have those lights and you need a h3 for low beam and h1 for highs
coregmrconman
08-27-2007, 02:21 AM
will 9006 fit?
low_down_xb
08-27-2007, 02:55 AM
no, you need h3 bulbs
coregmrconman
08-27-2007, 04:05 AM
what about these....
http://ssuperstore.com/images/4-HL~Toyota-XB-03-06_BK.jpg
low_down_xb
08-27-2007, 03:13 PM
i think you can use the 9006 with those
NEGATIVE211
08-30-2007, 11:06 PM
i have those lights u just posted, but the driver side doesn't have as much lighting power as the passenger side.
dmpsk8
08-30-2007, 11:43 PM
you may already know this but ill state just in case. u cant just wire hids into the sonars. ur gonna need a relay setup
burstaneurysm
08-31-2007, 01:20 AM
^ what? If you meant he needs a full HID setup then yes. But it's not different what housing you use. HID is HID, as long as you have the right lamp, it will work. HID runs cooler than halogen too, so heat isn't an issue.
dmpsk8
08-31-2007, 02:58 AM
yeah. to be more clear:
http://www.scionlife.com/forums/viewtopic.php?t=134365&highlight=hid+stock+wiring
dmpsk8
08-31-2007, 03:00 AM
and btw those lens in the sonars are nothing like the Blue-ion ones i have. they are way blue-er
burstaneurysm
08-31-2007, 04:56 AM
Yea, you meant HID harness... it still uses the stock relay, but it needs a new harness to prevent the stock harness from burning up.
coregmrconman
09-02-2007, 08:52 AM
i have hids for about 6 months on some other housings. (the ones with 3 little leds under the lamp) so i have an hid setup. i just need to know if hids will "fit" in them.
coregmrconman
09-02-2007, 08:55 AM
n btw i dont want them more blue dmp. my cars red n black. that would look weird.
low_down_xb
09-02-2007, 06:27 PM
YES hid will work in the new lamps and NO your old bulbs WILL NOT FIT in those new housings, geeeeezzzzzz..............................................
XBooster
09-07-2007, 12:36 PM
thanks all.
WHERE DID YOU BOUGHT THEM??? EBAY?? HOW MUCH??
