eD SQ10 in stealth box and NINe.4
Old Aug 28, 2007 | 04:21 PM
Aik's Avatar
Aik
Default eD SQ10 in stealth box and NINe.4
can anyone with this combo tell me if 150 W is enough power to run to the 10" ? seems kind of low to me, i was planning on using the front stage for components. was wondering if it is possible to drive it with a NINe.2X for some better output. thanks.
Old Aug 28, 2007 | 04:29 PM
equinox2355's Avatar
This is borrowed from eD's website: www.edesignaudio.com
Power Chart Explained :
Green Light : (Minimum / Starting Power). This is the minimum power recommended for the specific loudspeaker system. Using less power will not cause damage to the speaker but if using less there may be better items for the application. Yellow Light : This power range is ideally the category you want to be in. Using power within this range will allow you to extra all the performance out of the driver as it was engineered to exhibit. Even when using power in this region we urge you to explore the effects box design can have on your loudspeaker system. Power in this region retains high reliability and performance.
Red Light : This district is a place it's ok to be. But only if you know what you are doing. Power used in this region may have output gains but if used incorrectly can severely shorten the lifeline of the speaker and it's performance.
If using power in this region please contact a eD Technician
Black Light : You might be using the wrong speaker for your needs. If your using the specified driver in this power application you may be able to find a speaker that is better for your application or listening preference.
Old Aug 28, 2007 | 04:36 PM
Aik's Avatar
Aik
yeah i looked at that, i was wondering if putting about 250W, say from a NINe.2X with the gain turned down a bit, would improve output on the sub.
Old Aug 28, 2007 | 05:26 PM
250W should be fine for the SQ10
airmankevin1
Nov 17, 2015 05:44 AM
Schmohey
Oct 4, 2015 02:53 PM
jdmautoimports
Regional - Canada
Sep 24, 2015 04:00 AM
prescottn
Sep 22, 2015 01:30 PM
spharr62
Sep 20, 2015 01:44 AM
