HID help
Old Aug 29, 2007 | 01:59 AM
ThisDudePaul's Avatar
Default HID help
Now i'm not a noob when it comes to HIDs. Ive installed them in my previous car, and i've also read all the DIY so I knew exactly how to install them into the TC. I put the bulbs in place first, into the housing. then i connected them to the ballasts. I hooked up the power and ground wires. I left the passenger side female plug free and taped it up with electrical tape. Am i missing something? I was wondering if anyone has ever received HIDs that had bad bulbs from the company? or if the bulbs could have been damaged while in transit? how do i tell if the bulbs are bad or blown? the HIDs are Xenons. and i'm 99.99 precent sure that i hooked up all the wiring correctly. any help would be appreciated. thanks in advance.
Old Aug 29, 2007 | 02:05 AM
ADRdesignCo's Avatar
where did you get the HIDs from?
Old Aug 29, 2007 | 02:23 AM
from 3bspec.com
Old Aug 29, 2007 | 03:24 AM
BrakeDust909's Avatar
You know the ballast that has an oval silver shaped hole for the plug looks like this ( ) , well the plug(from the bulb) that goes in it turn it 180 degrees and then plug it in. hope that will work...
Old Aug 29, 2007 | 06:33 AM
yeah ive tried that too...plugged it in with the clamps facing the slanted metal part and the square metal part on the ballasts...nothing
Old Aug 29, 2007 | 06:45 AM
check your ground? does anything happen when you flip the switch? any sounds or anything?
Old Aug 29, 2007 | 07:01 AM
sillieidiot's Avatar
i don't think both bulbs will be bad. hmm did you use a relay? or just connected straight through using the car's wiring? check to see if the HIDs work by connecting them straight to the battery.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
