Axis widetrack wheel question
Old Aug 29, 2007 | 10:45 PM
pdjray's Avatar
Default Axis widetrack wheel question
Hi, I tryed do a search of axis widetracks but everybody seems to have the 18x8 front 60mm lip and rear 90mm lip.
Does anybody know if the 18x8 90mm lip will work all around and does anybody have pictures??
http://www.axiswheels.com/wheels/wid...idetrack.html#
THANKS!!!
Old Aug 30, 2007 | 05:44 AM
nebster's Avatar
no you need 60 up front. 90 will not allow you to go lock to lock
Old Aug 30, 2007 | 06:30 PM
CricketC's Avatar
90mm front will only work on a widebody tC.
Old Aug 30, 2007 | 10:15 PM
pdjray's Avatar
hmmm what do you mean by "lock to lock"??
Old Aug 30, 2007 | 10:18 PM
nebster's Avatar
turning the wheel all the way to the left or right
Old Aug 30, 2007 | 10:29 PM
Ace83's Avatar
Ronin Scion
If the offset is same it should be good, but I could be wrong coz it might hit your calipers.. and with different lip size front and back, you cant rotate your tires.. but looks cool though
Old Aug 30, 2007 | 11:10 PM
nebster's Avatar
with the widetracks its not the offset thats the issue with the 90 mm. its the backspacing it provides. it wont fit right and wont work.
Old Aug 31, 2007 | 11:59 AM
Ace83's Avatar
Ronin Scion
^^ yeah backspacing will be the concern since the wider the lip, the lesser is the caliper clearance. Neb is right its not the offset coz widetracks comes with a standard offset but maybe you can get 4 of the 80mm lip front wheel (yes, the fwd wide bodykit) and put it all around.. what fits the front should fit the rear.
Old Sep 3, 2007 | 07:25 AM
pdjray's Avatar
I never new they have a 18x8 80mm lip... will that work all around... if not.. what will? its just I want to be able to rotate my tires easiet way possible.. I love the widetracks (light and looks good) but if 60mm is the best all around do you guys have any other wheels similar with a big lip (18x8s, 19lbs)
Old Sep 3, 2007 | 07:27 AM
pdjray's Avatar
thanks for all your replys you guys....
Old Sep 3, 2007 | 12:35 PM
nebster's Avatar
no
TotalChaos
13
Feb 4, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
xbiyach
Oct 31, 2003 05:40 PM
scioninla
Oct 30, 2003 08:01 PM
1sikxb
Oct 10, 2003 07:47 PM
