Radio Configuration
Old Aug 31, 2007 | 12:08 AM
macadonious's Avatar
Default Radio Configuration
I know it is on this forum some where but I cannot find it. Please give me the link that shows and/or tells you how to go about altering your radio, such as placing your name in it or other interesting things that will customize ones setup
Old Aug 31, 2007 | 12:13 AM
ack154's Avatar
http://home.cfl.rr.com/icdedppl/faq.html
Old Aug 31, 2007 | 12:26 AM
Thank you. This helps tremendously!!!
Old Sep 1, 2007 | 08:34 AM
ThisDudePaul's Avatar
it's also in the owners manual if you bought your car new/still have it
Old Sep 1, 2007 | 11:07 PM
Default did not work for me
Please advise. I followed these steps:
6. how do i enable/disable the seatbelt reminder buzzer noise using the trip meter button?
to enable/disable that annoying seatbelt reminder buzzer, follow these steps using the trip meter button, but make sure you still buckle up!:
step 1
turn the key to the 'on' position. using the trip meter button, toggle the lcd until 'ODO' is displayed.
step 2
turn the key off. turn the key back to the 'on' position. within six seconds of doing so, press and hold the trip meter button for ten seconds. after ten seconds, buckle the driver's side seatbelt.
step 3
the buzzer by default is set to on. once you've held the trip meter button for ten seconds and then buckled the driver's side seatbelt, the lcd will then disply 'b-OFF', telling you that the buzzer is now turned off. you can now let go of the trip meter button. if pressed again in this mode, you will set the buzzer back to on, 'b-ON'.
*note*
if the battery or combination meter is disconnected, you will have to follow the procedure again.
Old Sep 2, 2007 | 02:22 AM
crabbyman's Avatar
OhioScions
These things are REAAALLY touchy..so the timing has to be precise.
Just make sure you "study" the instructions and do it from memory as quick as you can.
Old Sep 2, 2007 | 03:10 AM
When you say "quickly" what do you mean? Should I or should I not follow the 10 sec directions. It seems thatno matter how fast I am or if I could them write, it just will not work. Any tip for this?
Old Sep 3, 2007 | 02:03 AM
crabbyman's Avatar
OhioScions
I did this on the first try so it can't be too hard! haha..
Make sure ODO is on..turn car off..back on and instantly hold the odometer button for ten seconds.
I dont remember if you have to CONTINUE to hold the button when buckling the belt or not..try that?
prescottn
Oct 8, 2015 05:31 PM
dyenfd
Sep 13, 2015 10:00 PM
rhino8648
Sep 6, 2015 04:04 AM
umnitza
Sep 1, 2015 08:06 PM
semlin
Jul 29, 2015 02:07 AM
