valve cover leaking?
Old Aug 31, 2007 | 01:16 AM
mijos87's Avatar
Default valve cover leaking?
well i recently painted my valve cover, 2 weeks later my valve covers leaking oil! the area under the oil cap to be exact! the rest of it is fine im thinking the gaskets messed up, any ideas? i really need help with this one
Old Aug 31, 2007 | 01:21 AM
OldYeller's Avatar
Was too much oil put in?
Old Aug 31, 2007 | 02:48 AM
swartzautoman's Avatar
you painted your valve cover or your engine cover.
if it was the valve cover: take it back off and make sure the gasket is ok and be sure its all lined up real good when you put it back on.
you should also make sure you are tightening to bolts right (not enought/too much)
Old Aug 31, 2007 | 12:19 PM
autopainter13's Avatar
each time you remove the valve cover, you should replace the valve cover gasket and the two small orings on the top bolts
Old Aug 31, 2007 | 12:37 PM
i sould be a rubder gasket, you don't have to chang a rubber one unless its damaged.
if it was metal or cork yah you must change it every time.
Old Sep 1, 2007 | 02:10 AM
mijos87's Avatar
well i took it off and found out that, i ripped the gasket, well i know i can search it and i will but in case i dont find anything..... does anyone have the part number for the valve cover gasket?
tckid21
Mar 12, 2017 09:16 PM
smnHI
May 14, 2015 08:49 PM
SeT
Apr 1, 2015 07:39 PM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
peppy
15
Mar 24, 2004 10:48 PM
