Water Cooled Turbo?
Old Aug 31, 2007 | 10:58 PM
tCduck's Avatar
Default Water Cooled Turbo?
How does this work? Does it water lines run to it or is it internally cooled? Ive never messed with a watercooled turbo before.
Old Aug 31, 2007 | 11:11 PM
TurboToyotas's Avatar
Are you referring to a water cooled CHRA only or a GT style turbo that has both oil and water passages?
regardless it works just like a "oil" lubricated turbo works.
You get your water/coolant source from the motor. For example:
You have 2 coolant lines that feed your throttle body, you would splice into each of those for your feed and retun lines for your turbo.
Hope that helps.
Regards-
Todd
Old Sep 1, 2007 | 12:47 AM
aen's Avatar
aen
i want a wet bearing housed turbo. =P
Old Sep 1, 2007 | 07:43 AM
deathbyc4's Avatar
i want a jet engine.....
i have a water cooled turbo, has oil the cools and lubricated the bearing but the water cools the housing around the bearings. it lets you cool off the housing so it cuts down on the time to let the turbo cool down before turning off the engine. there's a cut-away of a gt turbo somewhere on the net.
Old Feb 21, 2008 | 05:50 AM
frostedsoul's Avatar
Can I water cooled big 16g EVO III turbo?
Old Feb 22, 2008 | 04:51 AM
deathbyc4's Avatar
only if the housing has the holes for it, aka four big holes on the center piece. i looked at some 16g pics, it looks like they have these holes.
Old Feb 22, 2008 | 05:52 PM
yamaha16bw's Avatar
For my brothers tC which is a turbonetics water cooled turbo I ran the lines from the throttle body. Very simple to do.
Old Feb 22, 2008 | 05:59 PM
Ace83's Avatar
Ronin Scion
watching.. so you just splice the lines and put a T on it going to the turbo?
Old Feb 22, 2008 | 06:03 PM
yamaha16bw's Avatar
I have the turbo lines running "inline" with the water lines for the throttle body if that makes since....so there is always flow.
Old Feb 22, 2008 | 07:46 PM
boosthappy's Avatar
i heard you can convert a wet flow internals to ball bearing internals is that true
Old Feb 26, 2008 | 04:06 AM
boosthappy's Avatar
any one
Old Mar 14, 2008 | 08:49 AM
Ace83's Avatar
Ronin Scion
Okay im almost installing my gt3076r, does anyone have pictures on how they tapped their waterlines? Ive read that one waterline should be lower than the other, and that the lower one will feed coolant going uphill while the higher will take the coolant away from the turbo. I just need pics or suggestions where the tap should be. I havent messed with coolant lines yet so im not sure where the coolant flow direction is. Help is appreciated
Old Mar 14, 2008 | 01:51 PM
Ace83's Avatar
Ronin Scion
anyone?
Old Mar 14, 2008 | 02:12 PM
I jus done coolant lines with my EVO III 16g! Kind of easy to connect the coolant lines! if anyone interested in, email me, I gonna show the detail! Good luck...
perfectboy1984@yahoo.com
Old Mar 14, 2008 | 02:16 PM
Ace83's Avatar
Ronin Scion
the 16g has a watercooled housing? can you show pics in here? or i'll email you later, thanks
Old Mar 14, 2008 | 08:16 PM
tom0613's Avatar
yes can u please post on how to do it because i have to run lines as well
Old Mar 16, 2008 | 01:10 AM
I dont know how to post the pics on SL here! give me ur email address, I'll send them to you.
Old Mar 16, 2008 | 01:12 AM
check this out, I bought this from Ebay, coolant pipe for turbo http://cgi.ebay.com/ebaymotors/ws/eB...195403471&rd=1
Old Mar 16, 2008 | 01:15 AM
tCtCtC's Avatar
PM'd u frostedsoul
Old Mar 16, 2008 | 03:45 AM
okay! I'll try to take some pics, tomorrow, its too dark now! its kinda easy to water cooled turbo! there are 2 coolant pipes run from the engine to throttle, T them and make the coolant lines for turbo
