Steel braided lines
Old Sep 1, 2007 | 03:03 AM
superboxcarxb's Avatar
Default Steel braided lines
How easy is it to install steel braided brake and clutch lines? Is there a how to somewhere on the forums on how to do it with pictures??? i searched and found something but the pictures didn't show up.
Old Sep 1, 2007 | 11:03 AM
Sciond's Avatar
hmmm I about to do this too
Old Sep 1, 2007 | 02:17 PM
aye87's Avatar
http://groups.msn.com/Sorensonbrian/...rakelines.msnw
Old Sep 2, 2007 | 11:03 PM
jetblast's Avatar
Just an idea, if you're gonna do any brakeline work, by some flare-nut wrenches. You can nab a cheap pair at Harbor Freight....they can save the day. Also, isolate your brakefluid from atmospherice exposure as much as possible....it naturally wants to absorb the humidity out of the air.
Old Sep 3, 2007 | 01:18 AM
streetlethalxb's Avatar
I have the clutch line in hand, and the braided brake lines in route..
not hard at all to instal, but make sure you bleed every last bubble of air
out of both before you drive. thats the important part, besides checking for leaks.
I have an air powered bleeder at work.. can do the brakes at all 4 corners
and the clutch quickly, but in a driveway, take your time...
Old Sep 3, 2007 | 01:20 AM
i'll do a quick write up on both, but the clutch line is fairly simple
10mm wrench, replace the line, bleed the air, done...
brake lines the same (size wrench? not sure)..
Old Sep 3, 2007 | 01:22 AM
Originally Posted by aye87
http://groups.msn.com/Sorensonbrian/ssbraidedbrakelines.msnw
this works..
Old Sep 3, 2007 | 08:53 AM
My main question is about the clutch line. I would like to know how to install the clutch line. I'm not too big on the brakes.
Old Sep 3, 2007 | 02:32 PM
Im gonna try to do a write up, without actually doing it..
just 'cuz im not in the mood.. but i'd like to help you out..
first heres what you need:
The line (mine is from Bonehead Performance)
Brake fluid (i'm using Motul RBF 600 race fluid=overkill, but w/e)
10mm flare nut wrench
10mm regular open end wrench
Pliers
here's the two ends you need to work with..
in the first pic, the red cicle is the complete end with the nut you need to loosen (circled in yellow), break it loose with the flare nut wrench, but do not remove (yet)
Next, remove the clip, that holds it to the bracket
after the clip is removed, comletley unscrew the flare nut with the regular open end wrench (you should switch wrenches basically because the flare wrench is a pain to line up, for every turn). Fluid pours out..
Next, repeat the same for the other end, pic below, (pain in the **** end)
the end circled in red
the clip cicled in blue
the nut circled in yellow
installation of new line is reverse order of removal.
After the new line is in, time to bleed the air, open the resevoir, fill it, open the bleeder valve (pic below, circled in red), bleed as you would brakes.. pump, hold, open bleeder, close bleeder, repeat, until no more air bubbles emit from bleeder, test pedal feel, keep doing this until it feels right. (need a partner)
Good Luck!!
Old Sep 3, 2007 | 02:52 PM
looking at your avatar..
I want a real mini sooo bad, panel truck version
Old Sep 4, 2007 | 09:19 AM
wow, thanks for the help. did you have to jack up the car for this???
Old Sep 4, 2007 | 09:21 AM
Do steel lines really make a difference in clutch feel or is it just for looks?
Old Sep 4, 2007 | 10:48 AM
No, don't have to jack up the car... I have yet to run one, but I am hoping for what is claimed:
"As many customers have come to find out, the clutch engagement feels very soft/weak and the actual engagement point is difficult to hit on the spot accurately. This results in slipping the clutch more than is needed. This mod is for anyone who is looking to get rid of that unpredictable clutch engagement. After installation of the stainless line kit will you will notice improved feedback and overall feel of the clutch system. "
Old Sep 5, 2007 | 09:03 AM
i dont know, based on your instructions, looks like there too much trouble to go thru just for that...I'll just stick to my rubber lines, plus i live in a condo. Cant really do anything over here with all the rules...
Old Sep 5, 2007 | 09:07 AM
do manuals have transmission oil or clutch fluid??? I've been wondering about it and thought i would need to change it....can't find it anywhere!!!
Old Sep 7, 2007 | 07:08 PM
hotbox05's Avatar
none of it's hard just gotta have fun bleeding the lines :/
oh and use dot4
dougcbx
Oct 23, 2015 11:42 PM
gqdabien
Oct 8, 2015 05:36 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
peruviann
Sep 14, 2015 06:35 AM
gottoaster
Sep 6, 2015 07:17 PM
