Tire wear on my scion XB
Old Sep 7, 2007 | 10:32 PM
sTIcKyrIce's Avatar
Default Tire wear on my scion XB
When I bought my xB I installed SS Tein springs and now my tires are getting eatin up both inside and outside. Do you guys suggest I get a camber kit or anything else to help the problem?
Old Sep 7, 2007 | 11:33 PM
burstaneurysm's Avatar
I would get it aligned first before getting camber kits... it's probably an issue with toe.
Old Sep 8, 2007 | 03:01 AM
hotbox05's Avatar
you busted out the toe. it's not that hard to do but in all of my 50+ scion lowering jobs none have ate tires.
Old Sep 8, 2007 | 06:43 AM
Spider13's Avatar
Check your tire pressure too.......
Old Sep 11, 2007 | 07:59 AM
CBSIMONSEZ's Avatar
Tires that wear on both outside shoulders are a sign of under inflation .. not an allignment problem. Allignment would wear only one side of the tire as the tire is being pushed down the road on more towards the left, right, or if both tires are either facing in or out.
Old Sep 27, 2007 | 08:15 PM
BoxOffice's Avatar
CBSIMON is correct! Tire wear inside AND outside is an inflation problem.
Although as others mentioned, an alignment is definitely in order after a spring drop, too...
scionlife
371
Jun 2, 2015 11:00 PM
TheTripleC
Jan 4, 2015 06:46 PM
Scionxa180
16
Dec 8, 2014 04:00 PM
xB_ey
20
Oct 19, 2003 03:04 AM
