Who sells pulleys for higher boost than 9.5lbs.? Thanks
Our 65mm (9.5psi) Pulley is one of our most popular pulleys and is usually kept in stock as often as possible.
We can also build different custom pulleys for various boost levels. Please feel free to look for me on AOL Instant Messenger at NSTonAIM or Email us from our website for more info if interested.
A big thank you to everyone who posted in response to the OP
Originally Posted by chubbykai
anyone know of any 10 or 10.5's ?
Yes - thats why I went with 10.5lbs because people are running 10lb's with the turbos and thats a lot more harsh then the s/c so I figured that as long as I was tuned (which I am) .....then a retune and 10.5 should hold up ok. The last thing I want is my head gasket blowing or something. Just be ready to wait 6-8weeks to get the pulley and the cost is more. IM them on AIM and get the details. Overall the pulley looks great ....I cant wait to get it installed.
you could make the crank pulley bigger and that would increase boost as well. problem with that is that i believe there is something that would get in the way if the crank pulley were to be enlarged.
^ but that would only need to happen when you couldnt make your s/c pulley any smaller (something that the trd s/c owner does not have to worry about) - I think a 14lb pulley will fit ... way more then my s/c will ever see
true, but the problem with getting a really small pulley would be the belt slip issue. so lets say you go 12lb pulley (+/- actual psi) and get a bigger crank pulley and you would actually see mayb 13-14psi vs. getting a really small 14psi pulley and not even seeing that much because the belt goesnt have enough pulley to bite on. but like i said, the bigger crank isnt really an option for us unless the particular person doesnt mind getting rid of whatever is in the way of making a bigger crank.
^ there is truth to what you say. My personal feeling is that if you are going to go above 12psi with the TRD s/c then you should be looking for another s/c setup ....i keep pondering over asking rippmods how much they would charge for a custom setup. No doubt they can make a lot more hp with a better blower
that'd be awesome to have another s/c for the tc out there. problem is that it would probably cost more then it's going to be putting out. and if we're talking different type of s/c, it would probably require some custom work with things in the engine bay to get it to fit under the hood. doesnt hurt to ask though
hey i have 2008 tc how do u take the bolt of to install pulley wat do i need
