Offset Offset Offset...
Old Sep 12, 2007 | 08:50 PM
deez's Avatar
Default Offset Offset Offset...
I keep asking about offset on wheels, and I thought i understood, but now I looked at the two sets of rims i'm debating between (planning to buy this week), and I dont remember, I confused my self all up. I forget what stock offset is. But the one set of wheels, the offset says +40 and the other says +45. Which one will look better? I want them to stick out further then stock if thats possible, so what would be the offset i'm looking for? Thanks guys.
Old Sep 12, 2007 | 08:54 PM
MrBurrito's Avatar
well i know the stock offset is 45 but knowing which offset makes the wheels stick out further still confuses me too
Old Sep 12, 2007 | 10:13 PM
DonNguyen's Avatar
the lower the offset, the further the wheels will stick out
wheel width will effect what offset you choose as well.
Old Sep 12, 2007 | 11:25 PM
deez's Avatar
Okay so the 40 will stick out more then the 45. sounds good to me. hehe
Old Sep 13, 2007 | 12:26 AM
Dakine's Avatar
Concept in Motion Crew
yes. but also make sure that the wheel width is the same or more than stock. ie if the stock wheels are 17x7. make sure the rims ur gonna buy are 17x7 or 17x7.5 or so on.
Old Sep 13, 2007 | 05:19 AM
Jdub86's Avatar
MN Scions
But a 40mm offset won't stick out far at all. Will you even notice it?
Old Sep 13, 2007 | 05:46 AM
Dakine's Avatar
uhh maybe, if your lowered.
Old Sep 13, 2007 | 02:39 PM
BZinn1's Avatar
.......35 may rub depending on drop.......seems 38-42 seems to be the most comman with 7.5-8 inch wide rims.......I am going with 40s on my new rims to eliminate any problems rubbing.
Old Sep 13, 2007 | 05:55 PM
DonNguyen's Avatar
most common width/offset combo is 7.5 with a +42 offset...
Old Sep 13, 2007 | 11:07 PM
Jdub86's Avatar
MN Scions
Well the rims that I will be getting have a 40 offset and I am lowered on TRD springs.
Old Sep 13, 2007 | 11:24 PM
BZinn1's Avatar
You should be fine......that is like right in the middle and TRD drop is fairly high still as is my Htech drop.....18s only raise the overall tire height just so slightly like a 1/4 inch into the well.....
Old Sep 14, 2007 | 03:35 AM
deez's Avatar
Im planning on putting 17x7 on stock suspenion right now, with 40 offset. any good?
Old Sep 14, 2007 | 03:43 PM
MrBurrito's Avatar
im pretty sure that'll work but why 17x7 thats the same as the stock rims unless you go 17x8 or 17x7.5 that'll look better
Old Sep 14, 2007 | 08:21 PM
DonNguyen's Avatar
17's are functional as far as diameter, but i'd at least go wider...
Old Sep 15, 2007 | 01:38 AM
a_german_named_hans's Avatar
That's what I have. It looked OK on the stock suspension. Love it with my Hotchkis drop.
Falken Circuit Specs. 17x7 +40mm offset.
Stock Suspension:
Hotchkis Drop:
Size of the tire also effects the way it looks. I have 225/45/17 Nittos on mine.
Old Oct 8, 2007 | 02:31 AM
pli's Avatar
pli
the lower the offsets, the more it sticks out.
wider wheels also make them stick out more.
Old Oct 9, 2007 | 12:08 AM
tcdrgn's Avatar
how about 18x8with a 35mm offset? would that make the rim/tire stick enough to match the fender line evenly?
Old Oct 11, 2007 | 06:01 AM
thebeast29's Avatar
those wheels look factory wit lip tho'
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
