post your 002's please
Old Sep 16, 2007 | 06:49 AM
Winter's Avatar
Default post your 002's please
i'm thinking about flaring the sides and throwing some 002's on. going to go 15x7 on the 0 offset with 225/50R15 Falken ZE512 tires. i'd like to really get a good look at these suckers, specialy if anyone has them matched to some 225/50-15 tires!
i will be droping an inch and half on some Tien SSP + EDFC for coilovers. should i worry about chambers? and if i do need to worry, where can i get some that are rather nice?
Old Sep 24, 2007 | 03:58 PM
nnnickkk's Avatar
you dont need flares for 7 inches wide.
Old Sep 24, 2007 | 10:27 PM
Winter's Avatar
i meant 8inch
Old Sep 25, 2007 | 12:56 AM
sizzlinscion's Avatar
Old Sep 25, 2007 | 02:24 AM
Winter's Avatar
so tell me how are the fender flares installed?
do you cut part of the fender edging off and then put the flares over that or what?
Old Sep 25, 2007 | 04:31 AM
you just put them against your car and and bolt them on
Old Sep 25, 2007 | 09:38 AM
Winter's Avatar
well i knwo that, i was just wondering how they help with wider wheels. do they pull the normal flare out with it so that the wheel doesn't rub?
Old Sep 25, 2007 | 05:54 PM
no they just stick out further than the normal fender
Old Sep 25, 2007 | 07:39 PM
burstaneurysm's Avatar
The fenders are merely a visual mod. The existing fender remains.
Sizzlin, maybe it's just the angle, but it looks like there's mad gap on the front wheel in the first pic... what's goin' on there?
Old Sep 25, 2007 | 08:32 PM
Winter's Avatar
ahh i see ok
so then should i worry about rub with 225/50/15 tires then? total diameter wise compared to stock it's only 2/10th's of an inch bigger and for ride higth i don't plan on droping more then an an inch and a half. for my purposes i'm also looking for higher compression springs for the back to go with the Tein SS-P coilovers being i'll have about 750lbs of extra weight primeral placed directly over the rear tires so i'm looking for stiffer springs from the back over 180lbs/in.
Old Sep 25, 2007 | 11:46 PM
its just the picture, you cant really see the tires in the picture
Old Sep 28, 2007 | 11:40 PM
Winter's Avatar
will i have rub problems with 225/50/15 with an aprox 1.5" drop?
Old Sep 29, 2007 | 07:21 AM
no you shouldntqa
Old Oct 11, 2007 | 04:25 AM
tohru's Avatar
nice fender flares
Old Oct 11, 2007 | 06:59 AM
Winter's Avatar
how about... 225/50/16 then?
or
245/45/16 ? *this is about 0.2" smaller then 225/50/16*
thanks.
Old Oct 11, 2007 | 07:30 PM
you should be fine with only a 1.5" drop
