whats up wth my car??
Old Sep 18, 2007 | 02:14 PM
meehoff's Avatar
Default whats up wth my car??
so i havent had the s/c on for more than 3000 miles and now that the weather is starting to change the car is acting like it dont want to start right up any reason why it's doin this?
jake
Old Sep 18, 2007 | 04:34 PM
chaseonbass's Avatar
Like its idling too high? if so thats quite normal. Howeer, mine seems to randomly idle very low as soon as the engine turns over then goes high. almost like its about to stall.
Old Sep 18, 2007 | 04:37 PM
draxcaliber's Avatar
well, isn't there an additional strain on the start to get the engine started since it has to turn the supercharger pulley too now?
Old Sep 19, 2007 | 02:34 AM
meehoff's Avatar
like it tries to turn over but i acts like it dont want too...and then if it turn the switch back off and try it again it starts up fine ...no high idol at all except for it idols high till it gets warm the back down to 7-9...
Old Sep 20, 2007 | 04:32 AM
Jedala's Avatar
Mine does the same thing. It tries to start, chugs and shakes a little, then dies. Crank it back up and it starts fine. I thought I finally had the s/c running smoothly,and it is, except for this.
Old Sep 20, 2007 | 08:46 AM
BurntClutch's Avatar
I noticed that too. I dont have a s/c or anything, just stock motor but now that its cooling off here in NC my car with less than 2500 miles on it is weird every once in awhile. It usually turns over real quick, but a few times now since the weather has started to cool down it has taken a few extra seconds for it to start up. Weird.
Old Sep 20, 2007 | 10:42 AM
monkeysauce's Avatar
what you're describing is high idle, where is will run at 1200-1500 rpm for a few minutes before dropping to normal idle
Idols are things people worship, FYI
Old Sep 21, 2007 | 02:15 AM
meehoff's Avatar
lol im the worlds worst speller but should i take it to the dealership of just ignore it
Old Sep 21, 2007 | 02:21 AM
Blue_TC_Man's Avatar
Might need a higher powered battery, cause the stock one has trouble starting mine, but I put a duralast gold from my work in and it turns right over, so as soon so Im done with everything looks wise on my car im going to buy a more powerful battery.
Old Sep 21, 2007 | 02:25 AM
meehoff's Avatar
i thaught about that are u s/c??
Old Sep 21, 2007 | 02:32 AM
**Edit**
No I wish lol, Im stock minus a CAI so if it wont start mine I doubt it helps to add an extra pulley. especially with the funky weather changeing the charge in the battery.
Old Sep 21, 2007 | 10:28 AM
paulky_2000's Avatar
I dropped-in an Optima battery...the Panisonic that was in the car really sucked. No starting troubles since!
---Paul
Old Sep 21, 2007 | 11:13 AM
For those that are having trouble with the Panasonic, how old is it? I've never seen a battery fail in less than 2 years without some type of abuse. I wouldn't know too much about them, because I swapped the Optima red top in my maxima with the panasonic stock battery right before I sold the maxima.
Old Sep 21, 2007 | 02:17 PM
Mines an 06 but the problem with the battery is the CCA I mean 50 more would have the car starting no problem
Jordly221
Feb 13, 2019 05:29 PM
2006sciontcva
Scion tC 1G Aero & Exterior
Jan 7, 2015 01:51 PM
TheTripleC
Jan 4, 2015 06:46 PM
minter66
Dec 15, 2014 01:45 PM
tC_Normo
Oct 22, 2003 07:20 PM
