HOW ITS MADE: Tanabe Sustec Lowering Springs (Factory Tour)
Old Sep 20, 2007 | 04:22 PM
Tanabe_USA's Avatar
Default HOW ITS MADE: Tanabe Sustec Lowering Springs (Factory Tour)
Tanabe performance coil springs have an extremely high tensile strength of 2100nm using only cold formed steel. This is the meaning behind the '210' suffix at the end of all Tanabe high performance coil spring lines. Within our manufacturing process lies the secret in the Tanabe spring's strength and extended durability.
Tanabe owns and operates one of the most advanced coil winding machines in the world. In addition to the coil spring machine, Tanabe springs are manufactured using several patent pending processes that cannot be found anywhere in the world!
1. COLD WINDING
Coil spring winding is the process where the high tensile steel is wound in the spring coiling machine, and the spring takes it's shape and length. Large rolls of high tensile steel are fed into this machine for the winding process. Using our advanced coil machine, our cold winding process maintains a very low temperature to wind the spring. Most springs are manufactured using an older hot winding technique, which heats the spring to a very high temperature to soften the material and make easier to wind. High heat, even for small amounts of time, unfortunately causes a detrimental side effect of causing the internal molecular structure of the steel to expand, which in turn weakens the overall strength. By maintaining a low temperature during our winding process, the internal structure is kept tightly packed, which maintains the steel's strength. Cold winding is the best process for producing a spring with extremely high tensile strengths. Because cold winding does not expose the material to high temperature, very advanced machinery such as ours is required. Most manufacturers are unable to cold wind their springs because less advaned winding machines would cause the high tensile steel snap if cold winding was attempted.
2. COLD TEMPERING
Tempering is a process that hardens and further strengthens the steel. Tempering improves the consistency of the internal structure to eliminate the possibility of weak spots within the spring. The coil springs are processed through this machine, which keeps them at a specific, constant low temperature for an exact amount of time. This process is monitored closely to ensure that temperatures do not vary so all remaining internal resistance at the molecular level is removed, and the spring increases its strength.
3. TRUE INDIVIDUAL SHOT PEENING
Shot peening is a process that shoots various size steel ball bearings against a surface, to cause beneficial unevenness of the surface, which improves tensile strength. Older shot peening processes perform this on one large batch of springs, which greatly reduces actual coverage. This machine is unique in that the coil springs are processed individually to ensure maximum and even coverage during the shot peen process. The coil spring is run through two unique shot peen processes, which is part of the confidential formula for Tanabe's 2100nm of tensile strength. This patent pending process for true individual double shot peening is unique to the Tanabe Shiga factory.
4. HUMID GRINDING
For the PRO210 adjustable coilover springs, the top and bottom edges are humid grinded flat, for fitment onto the seats and spring perches. Conventional grinding methods cause excessive friction, which causes high temperatures which dissipate throughout the spring, reducing overall strength due to heat expansion. The Humid Grinding machine is very advanced in that it does not produce excessive heat during the grinding process.
5. 100% LOADING
Loading of the spring is part of the final testing process after production. Loading the spring compresses the spring to measure the strength and ensures tolerances within the spring's structure. Conventional loading processes load it to a maximum of only 50-70%, which causes a possibility of sagging and deformity. Using this machine, the spring is compressed 100% to determine that each spring has full function, and will never deform. By loading the spring to the full 100%, the spring is pre-engineered and tested to never sag.
6. MEASUREMENT AND TESTING
Each specification for the spring is measured and tested after production, to ensure the spring rates and lengths are even and consistent, which ensures perfect fitment, function, and quality for all springs. The extra steps for quality assurance is part of why Tanabe has the world quality manufacturing certification, ISO9001.
7. POWDER COAT
After production and numerous inspection testing, the springs are finally sent for powdercoating and logos.
Old Sep 20, 2007 | 04:31 PM
p2filz's Avatar
that depresses me that they charge so much for metal tubing... but i guess its the proccess.. get airbags!!
Old Sep 20, 2007 | 04:51 PM
dugzilla's Avatar
That is really cool!
Old Sep 20, 2007 | 04:52 PM
2tone_xB's Avatar
interesting!
Old Sep 20, 2007 | 05:08 PM
aalbertson3's Avatar
Thats awesome! Thanks for sharing......
Old Sep 20, 2007 | 07:40 PM
superboxcarxb's Avatar
i feel like ordering springs now.....
Old Sep 20, 2007 | 09:43 PM
burstaneurysm's Avatar
That rules.
Old Sep 20, 2007 | 11:38 PM
boogi_man's Avatar
spiffy i guess i know what brand of springs i am getting now
Old Sep 24, 2007 | 04:16 PM
Tanabe_USA's Avatar
Glad that you guys found this information useful. If you have any questions please let me know!
heiko592
Oct 14, 2020 02:48 PM
scionlife
371
Jun 2, 2015 11:00 PM
ScionDP
Mar 1, 2015 10:57 PM
lunchbx05
Dec 29, 2014 07:53 PM
Scionxa180
16
Dec 8, 2014 04:00 PM
