motor mounts going bad?
Old Sep 20, 2007 | 08:23 PM
Gothbox's Avatar
Default motor mounts going bad?
has anyone replaced their motor mounts on the xB? my motor vibrates and you can feel it all over the car, the side mirrors are sometimes hard to look out of b/c of the vibrations, and stuff keeps coming lose as well. IS this the motor mounts going bad?, or is this something else?
Also where are the motor mounts located? and who makes replacements?
I have 93,600 hard driven miles on the car as well.
Thanx.
Old Sep 20, 2007 | 08:43 PM
nlataille18's Avatar
how 'bout a tune up
Old Sep 20, 2007 | 08:53 PM
jct's Avatar
jct
blip the throttle from under the hood and see if you have lots of engine movement, i say blip it kind of hard...
and a tune up is a good idea if you haven't done so already
Old Sep 21, 2007 | 04:04 PM
andrewdustin's Avatar
yeah, i have reaplaced all the motor mounts for another problem though. i agree with both guys above to do a tune up first and then have someone check it out. there are three mounts: (1) on the left hand side by the a/c piping,(2) underneath the battery (only accesible from under the car), (3) right behind the engine on the subframe. mounts should be a last resort because they are not easily changed out. also, have you ever changed you plugs? a lot of time that one simple thing can completely change the way a car runs, especially when it has almost 100K miles.
Old Sep 24, 2007 | 07:30 AM
itsme's Avatar
i have a broken rear mount and i dont have da same problem u have but i will be replaceing it after i finish building my second 1nz-fe which is a long time from now cuzz i gotta swap it all out in one day and not have any down time with my DD
Old Sep 24, 2007 | 10:27 PM
Gothbox's Avatar
ok thanks for the help guys, i have changed the plugs a few thousand miles ago, and just changed the oil and filter, about a thousand ago, what else should I check and change?
Old Sep 25, 2007 | 12:46 AM
air filter, fuel filter, fuel injectors, and etc.
Old Sep 25, 2007 | 12:52 AM
jct's Avatar
jct
heres some easy diy's well the fuel filter is most like around 6 on the 1-10 scale
the rest is easy
http://groups.msn.com/Sorensonbrian/fuelfilter.msnw
http://groups.msn.com/Sorensonbrian/...ycleaning.msnw
this one is a must
http://groups.msn.com/Sorensonbrian/yourwebpage.msnw
http://groups.msn.com/Sorensonbrian/...rcleaning.msnw
Old Sep 26, 2007 | 03:17 AM
Gothbox's Avatar
the filter is brand new,
Old Sep 26, 2007 | 03:19 AM
Gothbox's Avatar
Originally Posted by duck_dodgers_24_5
WOW I need to do this stuff then, I will make plans to do this stuff on my next day/days off. Do you think an external fuel filter would help/work? or should I only replace the factory?
Old Sep 26, 2007 | 02:36 PM
replacing the factory should be effecient.
Old Sep 26, 2007 | 04:31 PM
dugzilla's Avatar
I think he meant to say sufficient^^
Old Sep 26, 2007 | 10:32 PM
thanks for the correction. it was early in the morning if you note the time.
Old Sep 26, 2007 | 11:34 PM
dugzilla's Avatar
lol, it's all good. Lots of good info here, I changed my PCV valve today, and when I have more time I'm going to clean the throttle body too.
Old Sep 27, 2007 | 12:33 AM
Gothbox's Avatar
I mean do you think I could put a filter in the engine bay INSTEAD of changing the factory one? it seems like a lot of tedious work to change the factory one. so keep the factory one, and put a second new filter in the engine bay that would be a lot easier to change and keep a eye on.
thank you to everyone that has helped.
Old Sep 27, 2007 | 03:39 PM
well, the thing is if the factory filter is clogged with debris, then no matter how many new filters you put on, the factory one will still be inhibiting the flow of fuel. i agree with you though, the factory filter is a pain in the rear.
Old Sep 27, 2007 | 03:54 PM
Gothbox's Avatar
well that makes sense. thanx.
Old Sep 27, 2007 | 05:55 PM
no problem.
XirtaXa
24
Jan 14, 2025 03:49 PM
MinusPrevious
15
Dec 12, 2020 06:47 PM
Sumtallguy
Mar 24, 2015 04:55 AM
jenkay
Dec 17, 2014 03:25 PM
vitkh
Nov 30, 2014 02:27 PM
