4wd xb ..... will there ever be one
i was looking to find out if someone has made an attempt to build an xb 4x4 normal height? my friends just built a honda civic 4wd so i am inspired at this point. Check it out...
My buddy's from Epic Tuning ...As some of you remember we had a '91 EF
hatch with a stock Z6 engine making 375whp @ 24psi. At this power
level it ran 11.41 @121MPH. Since then we had turned it up some more.
It made 390WHP with a slipping clutch @26psi. We changed the clutch
and ran it at the track @ 28-30psi. The car ran 11.3@127mph. We
couldn't run anymore because the car had no roll cage. Instead of
turning it into a drag car we and the owner decided to go in a
different direction. We wanted to make it all wheel drive, work
through the problems and have a reliable 4WD civic for the street. We
converted the car to Real Time 4WD from a '89 Civic Wagovan. We used
the transmission, axles, driveshaft, viscous coupling, rear
differential and subframe. The clutch is a ACT 4 pad disc and Heavy
Duty pressure plate. So far at 24psi the drivetrain is holding up
great. We have a couple hundred miles and 40+ tire chirping launches
without a problem. We will keep putting it through its paces and see
what, if anything, breaks. We will have video up shorty along with new
all wheel dyno numbers.
http://www.honda-tech.com/zerothread?id=2104408&page=1
http://www.youtube.com/watch?v=Qxtf3_IHTfs
www.epictuning.com
www.epictuning.com
Originally Posted by low_down_xb
the bb in japan that is allwheel drive only come with a 1.3L w/automatic tranny only
there's three or four "4x4" xb's around.
the silver one on gigantic wheels is a photoshop
the silver pioneer db drag racing one is on a literal bronco frame
and the truck from sema above is only 2wd.
grzydj
38
Apr 1, 2005 01:58 AM
jasonbegin
Jan 14, 2005 09:35 PM
chucksu
Aug 27, 2004 02:24 AM
